Question about exhaust velocity and terminal velocity
The discussion centers around the relationship between exhaust velocity and terminal velocity in the context of a relativistic rocket model. Participants explore concepts of acceleration, mass, and energy conservation while addressing the implications of different exhaust velocities on the rocket's performance. The scope includes theoretical modeling and relativistic physics.
  • One participant models a relativistic rocket with constant power and questions the counterintuitive result that lower exhaust velocity leads to higher terminal velocity.
  • Another participant clarifies that a rocket in space does not have a terminal velocity in the traditional sense, as it can continue to accelerate with fuel.
  • There is a discussion about the definition of exhaust velocity, distinguishing between proper exhaust velocity and exhaust velocity as measured by an inertial observer.
  • A participant references the Baez FAQ to derive a formula for terminal velocity in the context of a photon drive rocket.
  • Participants discuss the need for clarity regarding the conditions under which exhaust velocity affects terminal velocity, particularly in relation to fuel consumption and acceleration profiles.
  • One participant expresses a need to modify their equations to account for constant wattage and variable accelerations, sharing their equations and variables used in the model.
Participants do not reach a consensus on the implications of exhaust velocity on terminal velocity, with multiple viewpoints presented regarding the definitions and conditions of the terms involved. The discussion remains unresolved as participants continue to explore the complexities of the model.
There are limitations in the discussion regarding the assumptions made about exhaust velocity and its measurement, as well as the dependence on the definitions of terminal velocity in different contexts. The mathematical steps and derivations presented are not fully resolved.
rhz_prog
I had made a model assuming a relativistic rocket accelerating with constant power,variable acceleration,variable total mass the result however is somehow counterintuitive. The less exhaust velocity the rocket have, the higher terminal velocity it will have.
Is that means I did something wrong ?
Terminal velocity is the final equilibrium velocity of an object against a drag force, typically in freefall. A rocket in space doesn't have a terminal velocity - it will continue to accelerate as long as it has fuel. The closest thing to it you can get is an abitrarily large rocket, regardless of the specifics of the rocket, will have a maximum velocity that approaches C.
Are you trying to calculate an acceleration profile in Relativity? My guess is that your error isn't with the relativity part, it's with the rocket exhaust velocity vs acceleration part. Could you give us the equation you are using...?
I am assuming you are asking if a rocket with a given total mass and a given fuel payload will reach a higher terminal velocity by the time it runs out of fuel, by using a lower constant exhaust velocity?
You have to specify what you mean by exhaust velocity. Do you mean proper exhaust velocity as measured by the observer on the rocket or exhaust velocity as measured by an inertial observer? If you mean the latter, you should be aware that the exhaust velocity will be getting less over time due to time dilation as a function of the rockets instantaneous relative velocity. In Newtonian calculations in a gravitational field, burning all the fuel as rapidly as possible is the most effecient way to launch a rocket and achieve the maximum terminal velocity for a given fuel load. It can be seen that the opposite extreme, is burning all the fuel so slowly that the rocket is only hovering and its final velocity when the fuel is exhausted is zero. From the Baez FAQ here http://math.ucr.edu/home/baez/physics/Relativity/SR/rocket.html it can be deduced that the final terminal velocity v/c of a photon drive (exhaust velocity=c) rocket is:
v/c = (F+2m)/(F+2m+2m2/F) where F is fuel load of the rocket and m is the payload of the rocket (total mass of the rocket less the fuel load).
Generally speaking the higher the exhaust velocity the greater the efficiency of converting fuel to momentum and the higher the terminal velocity of the rocket. You would have to make it clear about exactly what circumstances you are considering.
Yes I used Baez Relativistic Rocket FAQ to make my model.
I have to modify the equations though, since what I want is a model with :
- constant wattage
- constant exhaust velocity relative to the ship (is this the one called proper exhaust velocity)
- variable proper acceleration
- variable coordinate acceleration
The equations used is attached as 2 jpg images :
Mass Energy Conservation equation :
PBT*EPM*t = (MShip+MFuel-FBT*t)*c^2/(1-v^2/c^2)^(1/2)-(MShip+MFuel-FBT*t)*c^2+EXE
Linear Momentum Conservation equation :
(MShip+MFuel-FBT*t)*v/(1-v^2/c^2)^(1/2) = EXE/EXV
The variables used is as follow :
PBT : Mass of Fuel burned per unit time
EPM : Fuel Potential Energy per unit mass
MShip : Rest Mass of the Ship
MFuel : Rest Fuel Initial Mass
EXE : EXhaust Energy
EXV : EXhaust Velocity
The complete derivations I used is attached as mws file.
Thank you.
  • Relativity Travel-Momentum.mws
Oh I just remember that. Guess I will have to learn more English Physics Vocabularies.
Btw what I mean is the highest velocity the rocket would reach after using some part of its fuel to accelerate itself, provided that the rocket should have enough fuel to decelerate and arrive at its destination.
Yes it is given in the mws file I attached on my other reply above.
I think it is inappropriate for me to give the chaotic mws file like the first one I attached. This is the new mws file which have been divided to section. I hope this one is more readable.
Thank you
  • · Replies 31 ·
  • · Replies 37 ·
