Question about forces, velocities, accelerations, and slopes
  • Thread starter Thread starter WahooMan
    Forces
The problem involves an 8.0 kg box sliding down an inclined plane at a 30.0-degree angle, with an initial speed of 2.5 m/s and a coefficient of kinetic friction of 0.24. Participants are discussing how to calculate the final speed of the box by analyzing forces, velocities, and accelerations involved in the scenario.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the use of sine and cosine in calculating the normal force (Fn) and question how to determine which to use in different contexts. There are attempts to resolve the components of gravitational force acting on the box along and perpendicular to the slope.
Some participants have provided guidance on resolving forces and calculating components, while others express confusion about the application of sine and cosine. There is an ongoing exploration of the correct approach to find the final speed, with multiple interpretations of the problem being discussed.
Participants are grappling with the definitions and applications of forces in the context of inclined planes, particularly regarding the normal force and friction. There is a noted emphasis on understanding the role of initial velocity in calculations.
WahooMan
An 8.0kg box slides a distance of 4.0m down a plane that is inclined at 30.0 degrees with the horizontal. The initial speed of the box is 2.5m/s, and the coefficient of kinetic friction between the box and the plane is 0.24. Calculate the final speed of the box.
Fg=mg
Fn=mgcos(theta)? This is what my question is about
Ff=mu(Fn)
I have solved for Fg, but my question is how do I know when to use sine and when to use cosine in the equation to find Fn? I have noticed sometimes I get the correct answer with one and sometimes I get the correct answer with the other. How do I know when to use which?
Component of Fg which is perpendicular to the surface contributes to the normal reaction.
Component of Fg which is parallel to the surface contributes to the frictional force. Free body diagram will help you to decide which component to be used.
I don't understand. How do I know when to use sine and when to use cosine?
Find Fgsinθ and Fgcosθ. Νow see the directions of these components. And decide for what purpose you have to use them.
Fgsin(theta) = 39.2
Fgcos(theta) = 67.9
sin=y, cos=x?
So if I use sine to find my y component, Fn=39.2N Is this correct?
What is the frictional force?
In which direction it acts?
Which component pushes the box along the slope?
I don't know the frictional force because I don't know how to calculate Fn. I do know that the friction force acts in the negative x direction and the x component pushes the box along the slope. But without knowing how to calculate Fn I can't finish the problem. How do I know when to use sine and when to use cosine?
Resolve the components of weight mg along the inclined plane and perpendicular to inclined plane. Perpendicular component contributes to the normal reaction Fn. Horizontal component pushes the box down.
So Fn = 39.2N perpendicular to slope
Force pushing the box down the slope = 67.9N parallel to slope
Force of friction = Fn(mu) = 39.2(0.24) = 9.408N
Force of box sliding down the slope = 67.9N - 9.408N = 58.492N
Is all of this correct?
Please help me, I have a lot of studying to do and I've been trying to figure this problem out for more than two hours now. I just need to know in what situations I use sine and when to use cosine, not just in this problem but in general.
Ok, I've got
Fg = mg = (8)(-9.80) = -78.4N
Fn = mgcos(theta) = 78.4cos30 = 67.9N
Ff = mu(Fn) = 0.24(67.9N) = -16.3N
Fa = mgsin(theta) = 78.4sin30 = 39.2N
Sum of the forces = ma
(39.2+67.9-78.4-16.3) = 12.4 = 8a
a = 1.55 m/s^2
vf^2 = vi^2 + 2a(xf-xi)
vf^2 = 0 + 2(1.55)(4) = 12.4
vf = 3.5 m/s
But my answer key says I should be getting 5.4 m/s What am I doing wrong?
While finding out sum of forces, you have to consider only Fa and Ff. Fgcosθ is balanced by normal reaction Fn. So recalculate a.
(39.2-16.3) = 22.9 = 8a
a = 2.86 m/s^2
vf^2 = 0 + 2(2.86)(4) = 22.88
vf = 4.78 m/s
I'm getting closer, but I need 5.4 m/s
Initial velocity is not equal to zero. Read the problem again.
Wow.. I got it this time.. I hope I don't make such careless mistakes tomorrow on the test..
So I always use cosine when finding Fn? Would I ever use sine?
If you pull of push a block with a force F making an angle θ to the horizontal, then Fsinθ contributes to Fn.
  • · Replies 56 ·
