Question about Holonomy of metric connecton
  • Context: Graduate
  • Thread starter Thread starter lichen1983312
    Metric
6 replies · 2K views
lichen1983312
I am trying to follow Nakahara's book about Holonomy.
if parallel transporting a vector around a loop induces a linear map (an element of holonomy group)
[tex]{P_c}:{T_p}M \to {T_p}M[/tex]
the holonomy group should be a subgroup of
[tex]GL(m,R)[/tex]
then the book said for a metric connection, the property
[tex]{g_p}({P_c}(X),{P_c}(Y)) = {g_p}(X,Y)[/tex]
makes the holonomy group a subgroup of [tex]O(m)[/tex] if the manifold is Riemannian; and a subgroup of [tex]O(m-1)[/tex] if the manifold is Lorentzian.
The author must think this is very straightforward and didn't explain why. Can anybody help?
I assume the book you're referring to is Nakahara's Geometry, Topology and Physics, 2e.
This isn't what the book says. Nakahara actually writes [itex]{g_p}({P_c}(X),{P_c}(X)) = {g_p}(X,X)[/itex]
In any case, a linear transformation which preserves the inner product is the definition of an orthogonal transformation.
Also, Nakahara doesn't say that the holonomy group is a subgroup of [itex]O(m-1)[/itex] in the Lorentzian case, he says it's a subgroup of [itex]SO(m-1,1)[/itex].
If the connection is compatible with the metric, then parallel translation preserves the metric..
If the vector fields ##Y## and ##Z## are parallel along a curve with tangent vector ##X## then
##X⋅<Y,Z> = <∇_{X}Y,Z> + <Y,∇_{X}Z>## so the inner product of ##Y## with ##Z## is constant along the curve.
If the metric is Riemannian, that is: it is positive definite on each tangent space, then parallel translation is an orthogonal linear map. If the metric is not positive definite then parallel translation is an element of ##O(m-p,p)##. In the case of a Lorentz metric ##p=1##.
- If the manifold is not orientable then then a holonomy transformation may be orientation reversing.
Thanks for replying, this is very helpful, and I will try to keep the book close next when I am typing.
Now I seem to be able to understand the inner product preserving property make a orthogonal group, but can you explain where does the dimension (m-1) come from for Lorenzian case? Thanks
The m-1 comes from the fact that the inner product in the Lorentzian case is usually written with signature (m-1,1). That is, (-1,1,1,1) or (1,-1,-1,-1,-1) for 4d spacetime, for example. In the general case, this is the indefinite orthogonal group, and Nakahara is only considering the connected component which contains the identity. https://en.wikipedia.org/wiki/Indefinite_orthogonal_group
Thanks very much, now I see the point.
