Question about line integral of F dot dr
The discussion focuses on evaluating the line integral of the vector field F(x,y) = <3x², 2x+y> along a straight line segment from the point (1,2) to (5,4). The parameterization of the line is given as r(t) = <1,2> + t<4,2> for 0 ≤ t ≤ 1, which simplifies the evaluation of the integral. Participants also discuss alternative parameterizations and the importance of using "nice" forms for integration, particularly in cases involving circular arcs. The final integral is expressed as ∫<48t², 10t>·<4, 2> dt with bounds adjusted accordingly.
  • Understanding of line integrals in vector calculus
  • Familiarity with parameterization of curves
  • Knowledge of dot products in vector fields
  • Basic calculus skills for evaluating integrals
  • Learn about vector field parameterization techniques
  • Study the evaluation of line integrals in polar coordinates
  • Explore the concept of path independence in line integrals
  • Investigate the application of Green's Theorem in line integrals
Students and educators in calculus, particularly those focusing on vector calculus and line integrals, as well as professionals working with mathematical modeling and physics applications.
mesa
Evaluate the line integral of F dot dr where f(x,y)=<3x^2,2x+y> and C is a straight line segment from (1,2) to (5,4)
Unfortunately I was out with family obligations when we covered line integrals and surface integrals so am stuck with the textbook for these so I will just jump to my 'attempt at a solution' since I have limited knowledge on these subjects.
First I figured the equation of our line to be y=1/2x-1/2
so if x=t then,
y=1/2t-1/2
so r(t)= ti+(1/2t+3/2)j
and r'(t)= i+1/2j
∫<3t^2i+(5/2t+3/2j>dot<i+1/2j>dt
∫(3t^2+5/4t+6/2)dt
Then we evaluate the integral from 1 to 5. How bad is it?
so if x=t then,
y=1/2t-1/2
and r'(t)= i+1/2j
∫(3t^2+5/4t+6/2)dt
That should work; I didn't check your numbers. A nicer, and more standard, parameterizaton of the line would be ##\vec r(t) = \langle 1,2\rangle + t\langle 4,2\rangle## for ##0\le t\le 1##. I think you will find it simpler. Try it.
Ah hah, a surprising result!
If I have an integral of F dot T ds with F(x,y)=<4x,y^2> and C is the arc of a circle of radius 2 centered at the origin then do we just take,
x=2cos t
y=2sin t
so we have the integral of <8cos t,4sin^2 t>dot<-2sin t,2cos t> with the bounds of 0 to pi/2?
I thought I could figure this out, but...
How did you get that parameterization?
Given points ##P_0,~P_1## the displacement vector from ##P_0## to## P_1## is ##D=P_1-P_0##. Then ##R= P_0 +tD## is at ##P_0## when ##t=0## and ##P_1## when ##t=1##.
x=2cos t
y=2sin t
Sure, if that's the part of the arc in which you are interested. You can use any parametrization and the idea is to use "nice" ones, like that one, for a circle. Note that going from one point to another over different curves may (but might not) give different results.
Okay, so would r(t)=<5,4>+t<-4,-2> also be correct?
Sorry, I forgot to mention 'in the first quadrant'...
Nice to see the other part is correct.
Another couple questions, how do we take the derivative of r(t) in this form? Is it just 4i+2j? and then what do we do with our f(x,y)=<3x^2,2x+y> to set it up for the dot product in the integral?
Yes and no. Yes, it's the same line segment, but no, it is in the other direction.
Yes. The derivative of ##t## is ##1## so you just get the direction vector.
Remember ##r(t) = \langle x,y\rangle##. Your parameterization gives ##x## and ##y## in terms of ##t##.
Okay so we would have the integral of <48t^2,10t>dot<4,2> and the new bounds will be from 0 to 1 and then just calculus as usual. Is that right?
I haven't worked it out. But you could check by comparing the answer against your original calculation of the integral.
Very good, although I will rejoice when the semester is finished and this material can be covered properly (hopefully my copy of Anton will resurface soon as well, Stewart is a pain).
The only other question I have is if we have multiple 'segments' then we simply evaluate each one with their respective bounds and add the up, correct?
Yes.
Thank you LCKurtz, that should do it.
