- 4,305
- 49
Ah, right. Sometimes there are so many new posts in a few hours (or a day) that I fail to read them all :)
Fredrik said:And this is only part of the notation? The whole thing is ##\{(x,z)\,|\,\text{your statement}\}##? In that case, it still has the problem that the x,y,z have nothing to do with the (x,z). If your statement is true, the set will be "the set of all ordered pairs" (taken from any two sets), which I'm sure is too large to even exist in ZFC set theory. If your statement is false, the set will be ∅.
The part¬(x ∈ A ∧ ¬y ∈ B) ∧ ¬(y ∈ B ∧ ¬z ∈ C)says that if x is in A then y is in B, and if y is in B then z is in C. This is not true for all x,y,z.
You left out the ##x\in## at the beginning. You can type \dots or \cdots instead of ...reenmachine said:In the book of proof they introduced the concept of indexed sets.
From what I understood of it , ##A_{1} \cup A_{2} \cup A_{3} \cup ... \cup A_{n}## means that ##x \in A_{i}## in at least one of the set ##A_{i}##.
Yes.reenmachine said:If you replace the ##\cup## with the ##\cap## , then ##x \in A_{i}## for every set ##A_{i}##.
It gives us more options with the notation. For example, you can write ##\{A_i|i\in I\}## instead of ##\{A_1,\dots,A_n\}##. Instead of ending a sentence withreenmachine said:They talked about the set I , which is called an index set.They say that ##i \in I## .What exactly is the purpose of this set?
The symbol ##I## isn't assigned a meaning by the above. You have to explicitly say that ##I=\{1,2,3\}## before you can say that ##1,2,3\in I##.reenmachine said:Suppose we have $$\bigcup_{i=1}^3 A_i = A_{1} \cup A_{2} \cup A_{3}$$ does it mean that ##1 \in I## , ##2 \in I## and ##3 \in I##?
Looks pretty good. No need to post your experiments, since we have a preview feature. I used my new superpowers to delete your previous post, as requested.reenmachine said:trying my best to get used to LaTeX , not sure how the post will come out.
Fredrik said:You left out the ##x\in## at the beginning.
It gives us more options with the notation. For example, you can write ##\{A_i|i\in I\}## instead of ##\{A_1,\dots,A_n\}##. Instead of ending a sentence with...for all ##x\in\{A_1,\dots,A_n\}##.you can end it with...for all ##A_i## with ##i\in I##.
Yes. You could also end the sentence with "...means that ##x\in A_i## for at least one ##i\in\{1,\dots,n\}##".reenmachine said:Do you mean this:
##x\in A_{1} \cup A_{2} \cup A_{3} \cup ... \cup A_{n}## means that ##x \in A_{i}## in at least one of the set ##A_{i}## ?
Yes again.reenmachine said:Hmm ok , but in this case set ##I## would be the set of all numbers in ##A_{1} , A_{2} , ... , A_{n}## so ##I = \{1 , 2 , \dots , n\}## ?
Not really, because what if ##A_4=A_1\cup A_2\cup A_3##? Then we also have ##\bigcup_{i\in I} A_i=A_4##, suggesting that ##I=\{4\}##. Edit: I didn't notice that you put a 3 on top of the ##\bigcup##. That's not a standard notation.reenmachine said:Would this do the trick?
$$\bigcup_{i \in I}^3 A_i = A_{1} \cup A_{2} \cup A_{3}$$
Fredrik said:Yes. You could also end the sentence with "...means that ##x\in A_i## for at least one ##i\in\{1,\dots,n\}##".
Note that for all x,
\begin{align}
x\in\bigcup_{i\in I}A_i\ \Leftrightarrow\ \exists i\in I~~x\in A_i,\\
x\in\bigcap_{i\in I}A_i\ \Leftrightarrow\ \forall i\in I~~x\in A_i.
\end{align} What I mean by ##\exists i\in I~~x\in A_i## is "there's an i in I such that x is in Ai". This can also be written as ##\exists i\ \left(i\in I\ \land\ x\in A_i\right)##.
Fredrik said:Looks like I did that too quickly. The statement ##\forall i\ \left(i\in I\ \land\ x\in A_i\right)## would imply that I is a set that contains all sets, so it's nonsense.
Fredrik said:This can also be written as ##\exists i\ \left(i\in I\ \land\ x\in A_i\right)##. Edit: Nope, that last statement is nonsense.
micromass said:The only thing that's not allowed is to call ##\{x~\vert~P(x)\}## a set.
Fredrik said:I'm busy now, I'll explain what I was thinking later.
Yes, that's what I meant. This statement is OK:reenmachine said:What do you mean? Did you made a mistake in your previous post? (just to be sure we're on the same page)
This one is not:Fredrik said:Note that for all x,
\begin{align}
\end{align}
Yes, I understand that, but I saidmicromass said:I'm not sure why you think that this statement is nonsense. Something like ##\exists x:~P(x)## or ##\forall x:~P(x)## is perfectly allowed. Quantifiers can take as range all sets. The only thing that's not allowed is to call ##\{x~\vert~P(x)\}## a set.
Even if we replace ##\land## with ##\Rightarrow##, all we have there is a statement about the set x, so it can't by itself define the set ##\bigcup_{i\in I} A_i##. It says that for all ##i\in I##, we have ##x\in A_i##. This means that x is an element of every ##A_i## with ##i\in I##. A statement like that must be a part of the definition, but it can't be the whole thing.reenmachine said:Okay so I could also write ##\forall i\ \left(i\in I\ \land\ x\in A_i\right)## to define the second one?
There are only two standard notations,reenmachine said:What about this then?
$$\bigcup_{i = \{1,2,3\}}^3 A_i = A_{1} \cup A_{2} \cup A_{3}$$
I'm not sure what you've been trying to do, but yes, if you want to assign a meaning to the symbol I, you have to do it using one of the standard ways to specify a set. In this case, ##I=\{1,2,3\}## is the obvious option, and ##I=\{n\in\mathbb Z\,|\,1\leq n\leq 3\}## is one of the alternatives.reenmachine said:If not , I'm not sure what to do.Is it useless to try inserting the definition of ##I## in the notation or should I simply define it separately before starting to define some other set that ##I=\{1,2,3\}## ?
Lose the 3 on top, and the notation is fine.reenmachine said:EDIT: What I mean by this is doing something like:
Set ##I = \{1,2,3\}##
It doesn't really describe it. It's just an alternative notation for it. (And I think you meant ##A_{1} \cup A_{2} \cup A_{3}##).reenmachine said:...to describe the set ##\{A_{1} \cup A_{2} \cup A_{3}\}##?
Exactly.reenmachine said:It's not clear what ##I## is unless I previously defined it.
That's right. The statement would be true, but it doesn't tell us anything about the sets represented by the symbols in it (in particular A). Such statements are said to be vacuously true.reenmachine said:Suppose the set ##A = \{x~\vert~x \in A\}## , this would be an incorrect definition because it says nothing about A except that A is made of his own elements?
B' is only defined when all the sets we're working with are subsets of some set X. Then B' is defined as X-B. B' is not defined here.reenmachine said:Something like ##A = \{x \in A~\vert~x\not \in B\}## if ##A = B'## would be better because it explains what A is is that correct? But I can't say that ##A = \{x~\vert~x\not \in B\}##.
No, but you could say e.g. that ##A = \{x\in C~\vert~x\not \in B\}##, if you have already specified what C is.reenmachine said:But I can't say that ##A = \{x~\vert~x\not \in B\}##.
Right, you can't use the definition while you're stating it. But you also need to be careful when you use the notation ##\{x\,|\,P(x)\}##, because unlike ##\{x\in y\,|\, P(x)\}##, it's not guaranteed by the axioms to always make sense.reenmachine said:Why can't I say ##A = \{x~\vert~x\in A \land x\not\in B\}## ? Is it because I can't use A in it's own definition , a little bit like not using a word in it's own definition?
Fredrik said:Even if we replace ##\land## with ##\Rightarrow##, all we have there is a statement about the set x, so it can't by itself define the set ##\bigcup_{i\in I} A_i##. It says that for all ##i\in I##, we have ##x\in A_i##. This means that x is an element of every ##A_i## with ##i\in I##. A statement like that must be a part of the definition, but it can't be the whole thing.
$$\bigcup_{i\in I}A_i,$$ and $$\bigcup_{i=1}^n A_i.$$
First of all, you shouldn't have included the word "this", because it referred to the previous statement in my post. I assume that you meant thatreenmachine said:The earlier statement ''This means that x is an element of every ##A_i## with ##i\in I##'' would mean ##1,2,3 \in I## and ##x \in A_i##.If he is in ##A_i## and ##i \in I## then ##x \in A_1## , ##x \in A_2## or ##x \in A_3## , but since he either has blond , brown or white hair , how could he be an element of each ##A_i##? In a way , to find an element of the big set you have to find what's common between elements from the 3 subsets? Like ''being in the room'' in my previous exemple?
Several things here don't make sense. ##\forall i\in I## is only half a statement ("for all i in I such that"), so it doesn't make sense to say that "and" something else. I also don't understand what you're trying to do.reenmachine said:Set notation where x = a person in the room: ##\{ x\in\bigcup_{i\in I}A_i : \forall i\in I \land x \in A_i\}##
Yes to both questions.reenmachine said:Ok , so if ##I = \{1,2,3,4,5,6,7,8,9\}## then ##I = \{n \in\mathbb Z\,|\,1\leq n\leq 9\}##?
Ok so we only use the number or symbol on top with we have ##i=1## at the bottom and not ##i \in I## ?
You can, if you meant the singleton set whose only element is ##\bigcup_{i=1}^3A_i##.reenmachine said:What do you mean? I can't write it between {}?
I think that even in naive set theory, complements are always defined with respect to some set. You don't use the notation B' if it's not clear from the context what set ##B\cup B'## is.reenmachine said:Ok , so B' doesn't really exist except in naive set theory?
Fredrik said:First of all, you shouldn't have included the word "this", because it referred to the previous statement in my post. I assume that you meant that
x is an element of every ##A_i## with ##i\in I## ##.\qquad(1)##means
##1,2,3 \in I## and ##x \in A_i## ##.\qquad(2)##Clearly (2) is very different from (1). (2) tells us that {1,2,3} is a subset of I. (1) tells us nothing about I. (2) tells us that ##x\in A_i##. (What is i here?) (1) says that x is in all the A_i.
If you just want a notation for it, you can use ##\{x\,|\,\exists i\in I~~ x\in A_i\}##.reenmachine said:I was trying to write a set notation for ##A_{1} \cup A_{2} \cup A_{3}## with the knowledge that ##I=\{1,2,3\}##
Since ##A_{1} \cup A_{2} \cup A_{3}## means the same thing as ##\bigcup_{i=1}^3 A_i##, this wouldn't work as a definition, because of the problem of "using the definition while stating it".reenmachine said:$$\{x \in \bigcup_{i=1}^3 A_i : \forall i~~\left(i\in I\ \Rightarrow x\in A_i\right)\}$$
Would that be a better set notation for ##A_{1} \cup A_{2} \cup A_{3}##?
Fredrik said:If you just want a notation for it, you can use ##\{x\,|\,\exists i\in I~~ x\in A_i\}##.
Note that this wouldn't be a great way to define the notation ##\bigcup_{i\in I}A_i##, since it it's not written in the way that's guaranteed to be "safe". Recall that ##\{x\in y\,|\,P(x)\}## is always OK, but ##\{x\,|\,P(x)\}## is sometimes not.
If you meant this as a notation rather than as a definition, and you have previously specified that ##I=\{1,2,3\}##, then you would have to change ##\forall## to ##\exists##. If you do, you have a valid notation for ##\bigcup_{i\in I}A_i##. But the ##\in \bigcup_{i=1}^3 A_i## before the colon looks pretty strange. If you want to put a set there in order to ensure that the notation is in the form that's guaranteed to be safe, it should be a set that's guaranteed to exist by the ZFC axioms and contains all the elements of all the ##A_i##. (Edit: And it can't be the set we want to define).
If you're considering an example such as the one with hair colors, then yes. Otherwise, it's possible that some x is an element of several of the ##A_i##.reenmachine said:I'm still having some confusion on when to use ##\forall## versus ##\exists## , which I guess remains a big problem.I'm trying to pinpoint where I'm confusing the two in my thought process.If ##\forall i \in I \ x \in A_i## it would mean that if ##i=2## , then ##x \in A_i## which is not true since if ##i=2## then ##x \not \in A_1## and ##x \not \in A_3##.Is my observation correct?
Not sure I understand this question. What I'm saying is thatreenmachine said:Then the ##\exists## instead of ##\forall## in ##\exists i \in I \ x \in A_i## makes the connection between ## i \in I## and ##x \in A_i## possible?
That's understandable because I don't think there's a good answer. Maybe there is no better option than ##y=\bigcup_{i\in I}A_i##. Books on set theory don't define unions with a notation like ##\bigcup_{i\in I}A_i=\{x\in y\,|\,\exists i\in I~~ x\in A_i\}## and a clever choice of y. They do it by referring to the "axiom of union", which says (this is a direct quote from Hrbacek & Jech): For any set S, there exists a set U such that ##x\in U## if and only if ##x\in A## for some ##A\in S##.reenmachine said:I'm confused about what ##y## could represent if ##y## doesn't equal the set we're trying to define.
Fredrik said:Not sure I understand this question. What I'm saying is that
\begin{align}
\{x\,|\,\exists i\in I~~ x\in A_i\} &=\bigcup_{i\in I}A_i\\
\{x\,|\,\forall i\in I~~ x\in A_i\} &=\bigcap_{i\in I}A_i
\end{align}
If we apply this axiom to the set ##S=\{A_1,A_2,A_3\}##, the ##U## that the axiom says exists is the set we denote by ##\bigcup_{i\in I}A_i##. Since the axiom ensures that unions exist, there's no need to worry about the notation ##\bigcup_{i\in I}A_i=\{x\,|\,\exists i\in I~~ x\in A_i\}## not being in the "guaranteed safe" form.
I wouldn't talk about x as if it's not a dummy variable here. But the statement ##\forall i\in I~~ x\in A_i## does of course mean that ##x\in A_i## for all ##i\in I##.reenmachine said:Oh ok , so by taking the second one and saying it in reverse it's ##x \in A_i## for all ##i \in I## meaning that ##x## will be in every ##A_i##.
It doesn't really make sense to ask about a dummy variable, but it's true that an element of ##\bigcup_{i\in I}A_i## may belong to several of the ##A_i##.reenmachine said:Just to be sure , in ##\{x\,|\,\exists i\in I~~ x\in A_i\} =\bigcup_{i\in I}A_i## , ##x## could be in a single ##A_i## or multiple ones is that correct?
It is, because ##\exists i\in I~~ x\in A_i## is a statement about x, just like P(x).reenmachine said:To conclude with this , is ##\{x\,|\,\exists i\in I~~ x\in A_i\}## a notation of the form ##\{x\,|\,P(x)\}## ?
No.reenmachine said:But isn't the set U guaranteed to be the exact same set as S?
Fredrik said:$$\bigcup\{\{1,2\},\{2,3\}\}=\{1,2,3\}\neq \{\{1,2\},\{2,3\}\}.$$
Should be \bigcup instead of \cup here.reenmachine said:In your exemple , ##S = \{\{1,2\},\{2,3\}\}## and ## \cup \ S = \{1,2,3\}##.
This is like saying "x=x if and only if x=x". It's not wrong, but it doesn't really say anything.reenmachine said:##1 \in \{1,2,3\}## if and only if ##1 \in A## for some ##A \in S##.
This statement is a bit strange since A is a dummy variable, but I think I know what you mean.reenmachine said:##A = \{1,2\} \ or \ \{2,3\}##
This doesn't make sense. It should be ...for some ##A \in \{\{1,2\},\{2,3\}\}##.reenmachine said:so ##1 \in A## for some ##\{1,2\} \in \{\{1,2\},\{2,3\}\}##
This isn't really an example until you have specified what the ##A_i## sets are. So suppose thatreenmachine said:If ##S = \{A_1 , A_2 , A_3 \}## then what is ##\cup##? Can ##\cup = S## sometimes , like in this case? Or is it that ##\cup## will be the set of all elements of ##A_1## , ##A_2## and ##A_3## , while ##S## is simply the set with three elements in the form of ##A_i## ?
Fredrik said:This is like saying "x=x if and only if x=x". It's not wrong, but it doesn't really say anything.
\begin{align}
A_1&=\{1,3,5\}\\
A_2&=\{1,4,7\}\\
A_3&=\{1,5\}
\end{align}
What are the elements of the set
$$\bigcup \{A_1,A_2,A_3\} =A_1\cup A_2\cup A_2 =\bigcup_{i=1}^3 A_i =\bigcup_{i\in I} A_i?$$
Also, don't confuse the letter U with the symbol ##\bigcup U## in the Hrbacek & Jech definition.
Yes.reenmachine said:##A \in \{\{1,2\},\{2,3\}\}## means that A is either ##\{1,2\}## or ##\{2,3\}## no?
Right. This is the U in Hrbacek & Jech's definition applied to the set ##S=\{A_1,A_2,A_3\}=\{\{1,3,5\},\{1,4,7\},\{1,5\}\}##, and as you can see, S and U are very different.reenmachine said:##\{1,3,4,5,7\}## ?
I don't remember the exact definition of "expression" from mathematical logic (I think there is an exact definition), but ##\bigcup## is a symbol that's used in the notation for unions. It doesn't denote a set. It looks like a U because that makes it easier to remember that it's part of the notation for unions. In Hrbacek & Jech's definition, U is a dummy variable. The definition says that given a set S, there exists a set U with a useful property. What I said is that this set is often denoted by ##\bigcup S##.reenmachine said:Is ##\bigcup## = ##U## or not? Is ##\bigcup U## an expression? What I mean is I thought it was ##\bigcup S## and not ##\bigcup U##.I thought the set ##U## was already ''unionizing'' another set ##S##?
Fredrik said:Yes.Right. This is the U in Hrbacek & Jech's definition applied to the set ##S=\{A_1,A_2,A_3\}=\{\{1,3,5\},\{1,4,7\},\{1,5\}\}##, and as you can see, S and U are very different.I don't remember the exact definition of "expression" from mathematical logic (I think there is an exact definition), but ##\bigcup## is a symbol that's used in the notation for unions. It doesn't denote a set. It looks like a U because that makes it easier to remember that it's part of the notation for unions. In Hrbacek & Jech's definition, U is a dummy variable. The definition says that given a set S, there exists a set U with a useful property. What I said is that this set is often denoted by ##\bigcup S##.
