Why does sp2 hybridized carbon need an unhybridized orbital?
  • Thread starter Thread starter Crystal037
    Hybridization
The discussion centers on the necessity of unhybridized orbitals in sp2 hybridized carbon atoms, particularly in the context of ethene's geometry. It is established that sp2 hybridization results in a trigonal planar structure, allowing for the formation of π-bonds through the overlap of unhybridized pz orbitals. The conversation highlights the energy dynamics between hybridized and unhybridized orbitals, asserting that the interaction of pz orbitals in adjacent sp2 carbons leads to a lower energy state compared to a purely hybridized configuration. The debate between Pauling's and Huckel's theories on double bond formation is also noted, emphasizing the empirical nature of hybridization in introductory chemistry.
  • Understanding of sp2 hybridization and its geometry
  • Knowledge of π-bond formation and orbital overlap
  • Familiarity with Pauling's and Huckel's theories of bonding
  • Basic principles of molecular orbital (MO) and valence bond (VB) theories
  • Explore the concept of orbital hybridization in greater detail
  • Study the implications of π-bonding in organic chemistry
  • Research the differences between molecular orbital theory and valence bond theory
  • Investigate the role of hybridization in the stability of alkyl radicals and carbocations
Chemistry students, organic chemists, and educators seeking to deepen their understanding of hybridization and bonding theories in molecular structures.
Crystal037
why can't a carbon be sp3 hybridized and still form an ethene
carbon in ground state has electronic configuration=1s^2 2s^2 2p^2
why is sp2 hybridized carbon is need with only 3 hybridized orbitals and one unhybridized orbital? The unhybridized orbital forms a bond anyway. Then why can't they be hybridized and form the same bond
What is the geometry of sp3 orbitals? What is the geometry of sp2 orbitals? What is the geometry of ethene?
I know the geometry of sp3 orbitals is tetrahedral and sp2 is trigonal planar which is the geometry of ethene.
So is it purely based on experimental value than on p orbital shouldn't be hybridized to form a trigonal planar shape
In adjacent sp2 hybridized carbons the unpaired electrons in the pz orbitals can pair to form a π-bond, lowering the energy of the system. If you constrain the ethene carbons to be pyramidal (so that the orbitals are sp3 hybridized), that bond can't form--or at least the overlap between the unpaired electrons will be smaller. At any rate, the bent structure will be higher in energy.
why the overlap will be smaller. I am just saying than instead of overlapping of the carbon's unhybridized orbital pz with that of another carbon. Can't the two carbon have their orbitals overlapped in the hybridized state? the energy of hybridized orbital will definitely be less than that of unhybridized pz orbital
Ok I think maybe I understand what you're getting at, and it's a tricky distinction that's gotten a lot of attention in the research literature. If you're studying intro chemistry, it's probably best to simply accept orbital hybridization as empirical, but if you're still interested, we can do a deeper dive.
Pauling (the originator of the concept of hybridization) actually proposed that ethene's double bond was built from two sp3-hybridized CH2 units, sometimes called banana bonds, whereas Huckel was the originator of the notion that a double bond was a combination of a sigma and a pi orbital. Wikipedia has a decent overview of this debate:
https://en.wikipedia.org/wiki/Sigma-pi_and_equivalent-orbital_models
Long story short, from a computational point of view, both theories end up giving the same answer (which is really only an approximation to the actual answer).
One thing I should point out, though
This is more complicated than you might think. A carbon atom is a carbon atom, so adding up the energy for the 4 sp3 orbitals should give the same answer as adding up the energy for 3 sp2 orbitals and a p orbital. But also, you need to remember that you're dealing with the interaction of two carbon atoms to form a bond. So even if you have unpaired electrons in higher-energy pz orbitals, those orbitals interact to form a pi bond that is significantly lower in energy than the energy that you gain by rehybridizing the orbitals on the individual carbons.
One other thing: pedagogically, thinking about the double bond as a sigma-pi combination can help with wrapping your head around certain processes in organic chemistry. Alkyl radicals and carbocations generally have trigonal planar structures, so it's straightforward to assert that their singly occupied/free orbitals are unhybridized p orbitals, and it's easy to use this framework to justify stabilization of reactive radical/cation centers by neighboring groups.
DrDu said:
Strange article. It claims in the first sentence that it is about valence bond theory, but sigma - pi separation is a concept of MO theory.
Hm, I didn't notice that. It's actually a decent example of how MO and VB approach the same problem in different ways.
  • · Replies 18 ·
