Question about surface integrals on E&M
The discussion revolves around the application of Gauss's law in electromagnetism, specifically regarding the nature of the integral involved and the selection of Gaussian surfaces for calculating electric fields. Participants explore the distinction between surface integrals and line integrals in this context.
  • Participants question whether the integral in Gauss's law should be considered a surface integral rather than a line integral, and they discuss the implications of the notation used. There are inquiries about the arbitrary nature of choosing Gaussian surfaces and how that affects the evaluation of electric fields.
Some participants provide insights into the nature of the integral and the role of the differential area element, while others reflect on the implications of choosing different Gaussian surfaces. The conversation appears to be productive, with multiple interpretations being explored, but no explicit consensus has been reached.
There are mentions of potential confusion regarding the notation and the evaluation of integrals in problem-solving contexts, as well as the assumption that the electric field may vary with distance, which raises questions about its treatment in integrals.
Juan Pablo
I've seen on most books and in class that Gauss's law is usually stated like
\oint \vec{E} \cdot d\vec{A} = \frac{q_{en}}{\epsilon_0}
Shouldn't the integral be a surface integral rather than a line integral? I've seen times in problem resolution where they evaluate the integral as a normal integral rather than a surface one, is there a formal justification for this?
I have another kinda unrelated question. When you choose a Gaussian surface to calculate an electric field, is it chosen arbitrarily? I mean every surface with the desirable properties will do?
Thanks!
if you choose an arbitrary surface its arbitrary. and yes, an infinite amount of surfaces will have the same flux. and that also is a surface integral. I believe that symbol denotes only that the integral's bounds end and begin at the same point. the dA tells you that its a surface integral.
That is a surface integral because of the dA (element of surface area, sometimes written dS). The circle on the integral symbol indicates integrating over a closed surface that encloses the charge.
You can choose any enclosing surface that you are able to work out. Usually there is only one such surface that is easy to work out - where the E is known and is perpendicular to the surface everywhere.
I'm guessing that the area-as-a-vector thing is throwing you off. Your textbook probably explains how that works, but basically, for a small piece of a surface, d\vec{A} has a magnitude equal to the area of the piece and a direction perpendicular to the surface.
What usually happens is the dot product is being evaluated so that the integral becomes
\oint \vec{E} \cdot d\vec{A} = \oint |\vec{E}||d\vec{A}|\cos\theta = \oint {E\cos\theta} dA
where E=|\vec{E}| and dA=|d\vec{A}|, and with a clever choice of the gaussian surface, you end up with something like
\oint \vec{E} \cdot d\vec{A} = E \oint dA
When you take the surface integral, you're now just summing the area of all these little pieces of the surface, and the result is just the total area of the gaussian surface.
Is this what you were asking about?
That's pretty much what I was asking. Thanks a lot!. But isn't \vec{E} \cdot d\vec{A} an abuse of notation for the flux?
How so?
Apparently I misremembered. Another question, doesn't the electric field varies with distance? How is it possible to take it outside the integral?
That's where the choice of the gaussian surface comes into play. You take advantage of the symmetries in a problem to make the calculation easier. For example, if you have a spherically symmetric charge distribution, E will be directed radially, and its magnitude will depend only on r, so if you use a sphere as your surface, the magnitude of E will be constant and \theta will be zero, so you can pull E out of the integral.
  • · Replies 26 ·
