Question about the double-slit experiment.
42 replies · 9K views
No, the information definitely doesn't travel faster than the speed of light. When the state collapses, it is true that there is then zero probability of it turning up somewhere else. But this doesn't mean that information has traveled from the point of collapse to all the places where collapse might have happened.
To be clear, when information is transmitted, this means it would be possible to send some kind of message. So it is not possible to send some kind of message faster than the speed of light.
EDIT: maybe your definition of information is different from this, which is why we are getting our wires crossed.
Yes, I am using a different definition of information. Just in this instance - I do know what you mean.
What I mean by information in this instance, is the information that let's the entire wave know it has collapsed. So it doesn't collapse twice or more, in other places. These waves can be huge - light years across - billions of light years wide. Though when the wave collapses, the collapse can be conveyed across these vast distances.
Could someone please explain the actual detector? I've looked around quite a bit and haven't found anyplace yet that explains how a detector placed at one of the slits can both detect a single particle and also allow the same particle to pass through to the target. Logically one would think that in order to detect a single particle, that particle would need to hit the detector, in which case we shouldn't be the least bit surprised to find the interference pattern disappear. After all, the only slit letting anything through would be the one without the detector. Thanks.
I am not sure what they use in actual experiments, but the example I have seen is using a loop of wire around one of the slits. So this will let the particle pass through one of the slits, and you can tell which slit it went through because a current will be induced in the wire loop surrounding the particular slit that the particle went through.
Thanks Bruce. Allow me to elucidate. Home experiments reveal the principles of the effect, but don't actually use single photons or single electrons because the equipment isn't capable of doing that. I've also seen several computer animations of the experiment, but nothing that describes the method and principle that allows the detector to both detect a single particle and allow that same particle ( wave form or whatever ) to pass through the detector undisturbed to the target.
Typically we simply see a simplistic portrayal where an artist inserts an eye or camera into the animation that is supposed to represent a detector. The problem with such interpretations is that for our eyes or a camera to detect a single photon, that photon has to strike the surface of our retina or the camera sensor where it's converted into energy that is sent down a signal path and registered. The photon has been absorbed. Therefore if you were to actually use such a detector in the double slit experiment, the detector will catch the particle and the particle will never never reach the target. Logically this should have the same effect as covering one slit, and consequently the interference pattern should disappear.
The missing information is therefore, how does the detector actually work to detect a single particle? Logically, if it cannot interact with the particle in some way it cannot detect it, and if it does interact with it in some way it must have some interactive effect, and that interactive effect may well be the cause of the change in the pattern seen on the target. Am I making any sense here?
The double slit experiment can be understood in a completely "classical" way by considering a definite particle passing through one of the slits while an accompanying guiding wave passing through both. A macroscopic pilot-wave system has reproduced this (and there is no trouble with observing the particle):
If one of the slits were closed, the wave would be disrupted and the pattern is not found. Additionally you can easily imagine a measurement technique so heavy-handed (i.e. a floating buoy measuring the surface deflection) that would also destroy the wave-pattern. No mystery here, just a particle AND a wave.
Another recent experiment shows how a complex underlying pilot-wave dynamics can underlay a simple statistical description via deterministic chaos:
Good thing you used scare-quotes around the word "classical" :smile:
Yeah, of course we have to interact with the particle to be able to tell which slit it went through. And this is why the interference pattern changes when we choose to place detectors over the slits.
And yes, I have also seen videos explaining quantum mechanics, where someone just watches the particle, and then the particle chooses one slit to go through. Of course this is only telling part of the story, because the person must interact with the particle. You shouldn't take such videos too literally.
I would have chosen “the professor of ignorance” if allowed as a user name, as I’m a member from a completely different forum, asking a question for someone else. However, allow me to ask you this. If only having the option of choosing one video explaining what the term “observer effect” really meant, which video would you suggest?
I would suggest a lecture series. maybe MIT have something online. Or even type QM lecture into youtube. Some of the introductory lectures might have a good explanation of some of the concepts of QM, before actually teaching it.
The term 'observer effect' is a bit misleading itself. The way I see it, is that if we have some particle, then generally it will not be in an eigenstate of some measurable quantity. So when we do measure that quantity, we are forcing the particle into one of the eigenstates of the quantity we are measuring. So we are not merely 'observing', we are forcing it into a different state. It is only when the particle is already in an eigenstate of the quantity we want to measure, that we can take the measurement without affecting the particle.
Out of curiosity, what is the forum you usually go on?
Thank’s, I can see why your recognized as a curious homework helper. You never know.., perhaps the professor of ignorance may show up again
