Question about the universe structure?
  • Thread starter Thread starter Hyperspace2
    Structure Universe
The discussion centers on the structure of the universe and the nature of spacetime curvature. It highlights that while current cosmological models suggest spacetime is nearly flat on large scales, it is not perfectly flat, allowing for some curvature. The possibility of wormholes is debated, with the consensus being that significant curvature exists, but this does not rule out wormholes entirely. Participants express skepticism about the feasibility of creating wormholes, noting that current technology limits our understanding of spacetime curvature. Ultimately, the conversation emphasizes the complexity of measuring curvature and the implications for theoretical constructs like wormholes.
Hyperspace2
question about the universe structure?
I have a question.
Does universe consist curved spacetime everywhere? ,
I believe there are plenty of flat spacetime, isn't it? . If it is so then eveywhere worm hole is not possible isn't it?
Space news on Phys.org
According to current cosmological models, the curvature of spacetime is small, nonzero, and nearly constant on large scales. On smaller scales, you have, e.g., the region near the Earth's surface, which is more highly curved.
Perfectly flat? Not likely.
How does this connect logically to the rest of your post?
worm hole connects the shortest distance between two points in curved spacetime.
If majority of spacetime tends to be flat ,then we cannot drill that worm hole everywhere,isn't it ? or can we?
Not correct. The curvature of space is extremely small on large scales. There is very significant curvature of space-time, however, which we see as the expansion of the universe.
That said, we do not expect our universe to be, on average, perfectly flat (in terms of space). Our current observations show it's flat to within about a percent or so. But there is expected to be some deviation we can't (yet) detect.
if much percent of space was flat than , worm hole was not possible,isn't it?
Should we inspect before we make a hole.
I mean Dr Ronald L. Mallett couldnot make his wormhole in his laboratory, did he have to inspect some place to actually create wormhole.
There are other reasons to suspect that such wormholes don't exist, but the overall spatial curvature isn't one of them.
I think that bcrowell's statement is entirely correct. Curvature of spacetime is significant, but still small (i.e. large curvature radius).
The point is as you go to large enough scales, the curvature radius starts to become significant compared to the scales you're considering.
I suppose there is an intermediate set of scales where the space-time curvature can be considered small, though. At least on relatively short time scales.
You can't drill wormholes.
So I was under the impression that measuring the curvature to be about 1% was simply our limited technology. Is it definitely known that the universe could not possibly be flat, and why/how?
The first thing to point out is that the curvature is represented as a real number. This means that as long as you have physics which don't predict that the value must be some specific number, any specific number you might choose actually has zero probability of being the real value of the curvature.
Imagine, for instance, that we had initial physics that made for a probability that the curvature could be anywhere from -0.1 to 0.1 with equal probability in that range. The probability for any set of values being true is:
(# of values that match the condition)/(total # of possible values)
The problem here is that there is only one possible value that matches the condition of zero curvature, but there are actually an infinite number of potential values for the curvature between -0.1 and 0.1. In fact, there are an infinite number of potential values for the curvature between -0.00000000000001 and 0.00000000000001.
And then, when you put inflation into the mix, you recognize that the overall spatial curvature that we observe is a combination of the overall spatial curvature of the inflating patch plus a correction due to perturbations early-on during inflation. Since those perturbations are random, the curvature we measure just won't be identically zero, even if it just so happens that there is some weird physics that sets the overall curvature to zero identically.
why?
