Question about the Which Way experiment & the detectors used
  • Context: Undergrad
  • Thread starter Thread starter L1ght
    Detectors Experiment
The discussion revolves around the Which Way and Quantum Eraser experiments, focusing on the practical aspects of detecting particles in double-slit experiments. Participants explore the types of detectors suitable for monitoring particle paths and the implications of observation on wave function collapse.
  • Experimental/applied
  • One participant seeks a real-world video of a double-slit experiment with an actual which-way detector, expressing frustration with existing theoretical representations.
  • Another participant suggests that any digital camera sensor could be used to detect photons, recommending either a cheap handheld camera or a more expensive low-noise CCD or CMOS sensor for better results.
  • A participant questions what specific equipment is needed to observe and collapse the wave function, noting that their iPhone camera did not affect the results in their experiments.
  • One reply mentions that observing photons is challenging without absorbing them, indicating uncertainty about how modern experiments manage this issue.
  • A suggestion is made to use polarizing filters behind each slit to demonstrate the effect of observation on interference patterns, while also noting that the phenomenon is not as extraordinary as it may seem.
  • Another participant emphasizes that wave function collapse is a theoretical concept rather than a physical event, suggesting that it reflects a change due to interaction or measurement.
Participants express differing views on the nature of wave function collapse and the practicalities of observation in experiments. There is no consensus on the specific equipment required for demonstrating wave function collapse or the best methods for detecting particles.
Participants highlight limitations in understanding the interaction of photons with detectors and the theoretical implications of wave function collapse, which may depend on interpretations of quantum mechanics.
L1ght
TL;DR
What detectors are used in the which way (double slit) experiment and why aren't there videos showing the results of an actual which way (quantum eraser) experiment ?
Hello,
I have a question about the Which Way / Quantum Eraser Experiment.
I have tried my best to research online before coming to this forum to ask questions, so I apologize in advance if this question is novice but I have researched.
I have been looking for a YouTube "video" of a real world double-slit experiment that incorporates an actual "which way" detector (before of after the slit) monitoring which slit the particle travels through. YouTube has hundreds of double slit experiments but none show an actual live video of a detector collapsing the wave function. All of the video examples that I have observed (pun intended) that switch from "observed to unobserved" state are purely lecture based and not a live video. They simply show a graphic image of a camera/detector and how the detector (observer) theoretically collapses the wave function.
I am setting up a lab to conduct a few double slit experiments with and without observation and would like to get some ideas and feedback on the following:
1.) What kind of detector should I use that would record the particle path and collapse the wave function ?
2.) For the particle test, I will try experimenting by sending single photons using optic attenuators, but what can I use to record the collective single photon (particle) buildup test as is seen on many of the videos ? The examples I have seen appear to be software based displayed on a monitor.
Thanks in advance and sorry if these questions are novice.
Mike
For detecting photons any digital camera sensor can do that job. Grab a used handheld camera if you just want something cheap (be sure to get one with a removable lens if you need it for your setup), or spend a lot more for a cooled, low-noise CCD or CMOS sensor used for astronomy or other low-signal tasks.
Thank You ~
What type of test equipment should be used to collapse the wave function simply by observing ?
I have setup a DS experiment in my lab with green laser, it works great and I created 2 good videos. No problem.
I now want to transition from the Double Slit experiment to the wave function collapse by monitoring/observing/detecting/recording, etc... but I do not know what piece of test equipment changes the result simply be observing.
My iPhone camera was able to capture & record the double slit experiment without changing the result or collapsing back into the particle formation.
Do I have to use a specialized detector focused directly on one particular slit in order to demonstrate this collapse ?
Thanks in Advance,
Mike
That I can't help you with. Photons are very difficult to observe without absorbing them and I don't know how modern experiments get around this.
Thank You
You can put polarizing filters behind each slit. When the filters are both aligned in the same direction, photons reaching the screen will be in a superposition of "polarized on axis, went through left slit" and "polarized on axis, went through right slit" and will show self-interference. Rotate one filter so that each photon is "marked" according to which slit it went through and the pattern disappears.
If you think about this enough, you'll see that although it makes a much better demonstration it's really not any more amazing than just putting a brick in front of one of the slits... Which brings us to an often-misunderstood aspect of the quantum double slit experiment. The interesting thing is not that the pattern appears or not according to whether which slit is known/detectable. The interesting and uniquely quantum thing is that:
a) The pattern builds up a dot at a time when we use photons, not what we expect of a wave.
b) There is a pattern when we use electrons or other particles, not what we expect of particles.
(You might also take a look at Kim's delayed choice experiment. This technique for detecting which slit an electron went through is unfortunately far beyond the reach of any any amateur lab)
From a theoretical perspective wave function collapse is part of some interpretations of the mathematics of QM. It's not a physical thing.
And, more generally, collapse simply means change irreversibly based on some interaction or measurement.
Also, photons are relativistic particles and, strictly speaking, aren't described by standard non-relativistic QM. They are described by QED or QFT.
In general, therefore, you can't take the wave function collapse too literally. The example @Nugatory gave about polarisation exemplifies this.
That said, I'm impressed by your experimental efforts.
  • · Replies 36 ·
  • · Replies 49 ·
  • · Replies 33 ·
