What is the correct solution for this integral?
  • Thread starter Thread starter alba_ei
    Integral
The integral in question is ∫ (ae^θ + b) / (ae^θ - b) dθ. The initial substitution made was u = ae^θ - b, leading to an incorrect transformation of the differential. The correct approach requires adjusting both the integrand and the differential dθ to reflect the substitution accurately. The book's solution indicates that the correct integral evaluates to 2ln(ae^θ - b) - θ + C. Proper substitution and differential adjustment are crucial for arriving at the correct answer.
alba_ei
\int \frac{ae^\theta+b}{ae^\theta-b} \, d\theta
i took u = ae^\theta-b so e^\theta = \frac{u + b}{a} then i substituded back into the integral and iget this
\int \frac{u + b + b}{u} \, du
\int du +\int \frac{2b}{u} \, du
= u \du + 2b \ln u +C
= u + 2b \ln u +C
= ae^\theta-b + 2b\ln (ae^\theta-b)
but the answer of the book is
\int \frac{ae^\theta+b}{ae^\theta-b} \, d\theta = 2\ln (ae^\theta-b) - \theta + C
what did i do wrong?
You didn't subsitute properly. You have to change dtheta too.
write d0 as what it should equal to du
for example if u=x^2
du=2*xdx
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 22 ·
  • · Replies 21 ·
