Time Dilation: 2 Clocks in Same Ref Frame?
The discussion centers on the concept of time dilation and the synchronization of two clocks using a pulsar as a reference. It is established that clocks measure their own proper time and do not rely on reference frames. The conversation highlights that if one clock moves towards the pulsar and the other moves away, they will not reach the same time simultaneously due to the Doppler effect. The complexity of synchronizing clocks over vast distances is emphasized, with the conclusion that synchronization processes must be clearly defined and will yield different results depending on the states of motion of the clocks.
  • Understanding of time dilation and proper time measurement
  • Familiarity with the Doppler effect in the context of light and timekeeping
  • Knowledge of Einstein's synchronization method for clocks
  • Basic concepts of reference frames in physics
  • Research "Einstein synchronization method" for clock synchronization techniques
  • Explore "Doppler effect in timekeeping" to understand its impact on clock measurements
  • Study "proper time in relativity" to grasp how clocks measure time independently of reference frames
  • Investigate "pulsar timing" as a method for precise time measurement in astrophysics
Physicists, students of relativity, and anyone interested in the complexities of time measurement and synchronization in high-velocity scenarios.
maxpower2020
Question about time dilation. What if two clocks used the same reference frame? For instance, 2 countdown clocks using a particular pulsar as a measure of time. One stays here, the other is sent 100 million miles away at a very high velocity. Would they still reach 000 at the same time?
In the usual meaning that scenario would involve only a single clock: the pulsar.
This is rather confused. Clocks measure their own proper time - they don't use reference frames.
These aren't really clocks, if I understand your setup. They're basically counters attached to telescopes and they count the pulsar flashes they see.
Depends where they are in relation to the pulsar and what you mean by "the same time". If the counter that you move goes directly towards the pulsar then it will see pulses earlier than the stationary counter, so will finish earlier. If the counter moves directly away then it will receive pulses later and finish later. If it moves in any other direction then it's frame dependent - there exists a frame in which they finish simultaneously, but there are frames in which either counter finishes first.
There can be advantages to this approach to timekeeping, although there are some changes that need to be made to your process. But it really doesn't work well for moving clocks, and it definitely doesn't save you from the relativity of simultaneity.
Suppose one were sent directly toward the pulsar and one directly away from it. Do you think it would take the same amount of time for each to accumulate the same number of pulsar-ticks?
EDIT: I see ibix beat me to it.
Okay I understand more and am confused even more. First off measurement of time is totally arbitrary, it depends on what we all agree upon. Our clocks on Earth are measured in our gravity, and in our reference frame, and on a agreed upon definition of a second.
Is not a cesium clock (or any other) just a frequency counter?
I do get the the different velocities, and looking forward to thinking this through. I love learning new things. Even when I find out I was wrong, it means I learned something new. And this is part of a bigger question I want to ask, but I want to get my foundations right first,
My original thought certainly drifted, but thanks I have a lot of new stuff to think about. My original thought was if there was any way to keep 2 clocks in sync, one here one there. And it doesn't matter what the intervals are, as long as they agree. I know we have the physics and the math to deal with it, like GPS, but is there any way to do it at great distances, real time with accuracy? Or on the other hand, reliably deal with any inaccuracies?
Yes, it is called a “frequency standard”. A clock is a frequency standard with a counter, but the frequency standard is the thing that makes a clock a clock.
In your OP there was only one frequency standard, the pulsar. You had two counters, but the one frequency standard makes it one clock.
Measurement of time is not arbitrary. The units used are, sure. But once you've agreed that, a second is a second is a second and had nothing to do with reference frames, gravity, or anything else. All that kind of thing comes in when you want to work out what my clock says at the same time yours says 12.00.00. Furthermore, two correctly calibrated clocks sitting side by side will tick at the same rate. That isn't arbitrary behaviour.
But you asked about clocks "using the same reference frame". Reference frames are abstract concepts used to analyse or describe experiments. Clocks are physical devices that do what they do regardless of the reference frame you analyse them with.
Not quite. It's a frequency counter with a stable cyclic process - a source of pulses with a fixed frequency. Your counters aren't attached to the source, so they don't see a fixed frequency due to the Doppler effect - so they will sometimes count at the same rate as a clock sitting next to them and sometimes won't. So they aren't really clocks.
A great many ways, most giving different results. One of the lessons of relativity that seems to be the hardest to learn is that "synchronised clocks" is not a complete concept. You need to specify your synchronisation process and the states of motion of the clocks that are being synchronised. And you need to accept that no process gives clocks that everyone will reasonably describe as synchronised.
Your approach could be turned into a clock synchronisation procedure by measuring the distance to the pulsar and correcting for both the distance and the rate of change. However, this ends up just being a difficult to implement version of (probably) Einstein synchronisation in the pulsar rest frame since it depends on how you define distance to the pulsar (and that gets very messy close to the pulsar because it's a large object).
Please, I'd like to confirm the invoked frame is in these two statements -
I think maybe its an earthbound telescope watching both counters? Or is it either counter? Or all three?
Mine was a specific statement about when the pulsar and both counters are in a straight line ("the counter that you move goes directly towards the pulsar"). In this case the reception events of a particular pulse are null separated and order is invariant. When the three are not colinear then the reception events are spacelike separated and the order depends on frame.
Took a little thinking but now I'm starting to understand. I really appreciate the answers and the time spent helping me get a handle on my question.
It makes no difference which reference frame you use to take the measurement. The clock measures the passage of its own (i.e. proper) time, something that's the same in all reference frames.
  • · Replies 54 ·
  • · Replies 88 ·
  • · Replies 22 ·
  • · Replies 26 ·
  • · Replies 58 ·
  • · Replies 21 ·
  • · Replies 83 ·
