Question about vector spaces and subsets
  • Context: Undergrad
  • Thread starter Thread starter green
    Space Vector
8 replies · 3K views
green
V is a vector space and W is a subset of V. could W be a vector space but not a subspace of V?
on Phys.org
A subspace ##W## of a vector space ##V## over the field ##\mathbb{F} ## is a set with the properties ##W\subseteq V## and
c\cdot a\in W \text{ and }a-b\in W \text{ for all }a,b\in W \text{ and }c\in \mathbb{F}.
This makes any subset ##W## that is also a vector space a subspace of ##V## per definition. The only way out of this automatism is to define two different vector space structures on ##W## and ##V##.
An example: Consider ##V=\mathbb{R}## and ##W=\{0,1\}.## Then ##W\subseteq V## is a subset of the real vector space ##V.## Now, ##W## is no real subspace, but it is an ##\mathbb{F}_2## vector space. So we have a subset ##W## that is a vector space, but not a subspace of ##V## because both vector space structures are incompatible: ##1+_W1=0## and ##1+_V1=2.##
Reply
That was very helpful! Thanks.
Reply
fresh_42 said:
No, at least not if the addition is the same.
Counterpoint: ##\mathbb{Q}\subset \mathbb{R}##, is a 1 dimensional vector space over itself but it's not a subspace of the one dimensional real vector space ##\mathbb{R}##. I would argue the addition is the same :)
Reply
Yes, I should have written 'vector space structure' instead of addition. Laziness is always punished. Your 'counterexample' is the same as mine, only with another field.
It's also important to specify the field of scalars, which is part of the definition of a vector space. The Real numbers are a subset of the Complex numbers and a real vector space, but not a complex subspace.
Duh, I don't get why not. Care to enlighten me?
I'm going to do things over two dimensions, to make the difference between scalars and vectors a bit more obvious. ##\mathbb{Q}^2## is obviously a 2 dimensional vector space over ##\mathbb{Q}##. It is also a subset of ##\mathbb{R}^2##. This is both a two dimensional vector space over ##\mathbb{R}##, and an infinite dimensional vector space over ##\mathbb{Q}##. If you think of it as a vector space over the real numbers, ##\mathbb{Q}^2## is not a subspace because it is not closed under scalar multiplication: ##(1,1)\in \mathbb{Q}^2## but ##\pi(1,1)=(\pi,\pi)\notin \mathbb{Q}^2##.
