Question (body immersed in fluid)
  • Thread starter manal950
  • Tags
    Fluid
In summary, the conversation discusses a problem involving a submerged plate with a triangular shape and the determination of the center of pressure and total pressure force. The initial diagram and calculations were incorrect, but the final diagram and calculations were corrected with a few adjustments. It was also noted that the pressure computation was off by a factor of 10.
manal950
177
Hi all
Can please check my answer in this Question ?
and Is my diagram correct ?
http://store2.up-00.com/Mar12/PD451302.jpg
thanks
where are you ?
Do you have the plate upside down?
you mean that diagram is wrong ..
Problem states base is 4 m long. It is not 1 m from surface...the way you have it drawn.
As Problem state the base of triangular is four m while the height is 6 m ... and from free srface is immersed at the one m
Now is the diagram correct
http://store2.up-00.com/Mar12/NjT38265.jpg
Yes, the sketch is now correct.
ok what about other answers
You should rework the problem. Let's see your work.
p = pgh
= 900 X 9.81 X 3
= 26.5
but the unit here is kpa or N/m^2
Now center of pressure
= (IG / AX ) + X
= bh^3/36 = (4X 6^3) / 36 = 24
so now (24/12X 1 ) +
= 5
When the problem says "determine the total pressure", it is unclear whether they are seeking the total pressure force due to the pressure at a designated point.
The designated point is generally the center of mass of the triangle. You have not calculated that. The center of pressure is a function of the moment of inertia, the area, and the center of gravity of the plate.
So you need to compute those three items first. Your moment of inertia is incorrect.
Is the plate not fully submerged? Did you quote the problem statement exactly?
yes plate fully submerged
The center of pressure is located at the centroid of the triangular shaped pressure field 2/3 from the top of the water line."
From this I may compute:
1 + 2/3 .6 = 5
The location of the centroid is 1/3 the distance from the base of the triangle to the apex opposite the base along the height of the triangle. What is the height (altitude)? Ybar=h/3. First you must determine h, then add the 1.0 to it.
I have a little difficulty
seeee...
Now I want know Xbar is 3 or 5 ?
I will try ...
presure = pg(xbar)
= 2.6 kpa----------------
2)
Center of pressure
Center of pressure =( IG/Area(xbar) ) = xbar
IG = bh^3/36
IG = 4 X 6^ / 36 = 24
Area = 1/2 X 4 X 6
= 12 m^2
Now ..
Center of pressure = (24 / 12 X 3) + 3
= 3.6 m pleeeeeeeeeeeeese help me now what is the wrong ..
You calculation for center of pressure looks good except for round off error. I get 3.66 which rounds to 3.7 m for the center of pressure. You use the distance that the centroid of the triangle is below the surface for the calculation. It is 3 m.
Your pressure computation is off by a factor of 10. It should be 26 KPa.
What is Archimedes' principle?
Archimedes' principle states that an object submerged in a fluid will experience an upward buoyant force equal to the weight of the fluid it displaces.
How does the density of the fluid affect the buoyant force?
The buoyant force is directly proportional to the density of the fluid. The denser the fluid, the greater the buoyant force.
How does the depth of immersion affect the buoyant force?
The deeper an object is submerged in a fluid, the greater the buoyant force it experiences. This is because the pressure of the fluid increases with depth, resulting in a higher upward force on the object.
What is the relationship between the volume of the object and the buoyant force?
The buoyant force is equal to the weight of the fluid displaced by the object. Therefore, the greater the volume of the object, the greater the buoyant force it will experience.
How does the shape of the object affect the buoyant force?
The shape of an object does not affect the buoyant force it experiences. As long as the object is submerged in a fluid, the buoyant force will be equal to the weight of the fluid it displaces, regardless of its shape.
