Question - Distributed weight on Camper Tires
4 replies · 2K views
LarryG
Let say I have a 4,000 lb. camper with two axles (four tires). There is 400 lbs. of tongue weight on the hitch which would leave the remaining 3,600 lbs. distributed to the four tires (900 lbs./tire). To keep it simple, let's say the weight of the camper is distributed equally left and right. Now my question is; if one of the tires goes flat, (1) will the tire remaining on the flat side now be also supporting the weight of the flat tire (for a total of 1,800 lbs.), or (2) will the 900 lbs. from the flat tire be distributed to the remaining three tires so that each tire is now supporting 1,200 lbs.? Looking forward to your input. I hope I picked the correct forum and level. Thanks in advance. Larry
On a travel trailer forum, it's generally stated that if you have a flat tire on a dual axle trailer, the remaining tire on that side will carry the full weight of that side of the trailer. The issue is if you drive on that single tire on the flat side, how much weight is on that tire so you can know if you are exceeding the tire's Load Range. I have no reason to back up what I think but I'm thinking why wouldn't the three remaining tires act like a tri-pod with the weight spread equally. Larry
based on just intuition / personal opinion as opposed to any technical analysis of the situation, I'd say that in uniform straight travel the single tire would likely support less than half but possibly more than 1/3rd of the weight. The real problem would be when turning into the side with the single tire, in which case that tire would likely take more than half of the vehicle's weight, creating quite a problematic situation.
Your dual axel gives you a massive advantage for getting somewhere safe when you have a flat. The stress on tyres depends quite a lot on speed so I would perhaps risk carrying on my journey very slowly for a short way. The best solution would of course depend on the exact circumstances but if the trailer is fully loaded you are clearly exceeding its specified load and you are on your own as far as Insurance and warrantee conditions are concerned. I agree with phinds and his estimation of probable load (cornering will make things much worse).
