Question involving 2 pulleys and 2 masses.
  • Thread starter putongren
    Pulleys
putongren
Diagram of a pulley system: block m1 hangs from a string over a fixed pulley at the left, and the string runs to a movable pulley, with block m2 attached to the right on a horizontal surface and a string fixed to a wall at the top right.
1. Homework Statement
If the magnitude of the acceleration of block m1 is a, what is the magnitude of the acceleration of block m2?
None.
The answer is 2a. Is it because the top string of the right pulley is adding string, while simultaneously, the lower string is subtracting string while the right pulley goes left pulling mass2? The motion is constrained by the pulley. The result would cause the mass2 to go twice the distance than mass 1. Since distance is related to acceleration, acceleration is twice as well.
your explanation is very good however I would add that distance is related to acceleration and time, and the time for each mass to move its respective distance is the same.
