Question on calculated friction force between a ramp and a cart
This discussion focuses on calculating the friction force between a cart and a ramp using the cart's mass and acceleration values. The cart's mass is 0.265 kg, with an acceleration of 0.369 m/s² down the ramp and -0.435 m/s² up the ramp. The calculated friction force, initially found to be -0.107 N, was corrected to approximately 0.009 N after addressing sign errors in the acceleration measurements. The conversation highlights the importance of maintaining consistent directional measurements and introduces the concept of torsional friction affecting the overall friction force.
  • Understanding of Newton's laws of motion
  • Familiarity with basic physics concepts such as friction and acceleration
  • Knowledge of forces acting on objects on inclined planes
  • Ability to perform calculations involving mass, acceleration, and forces
  • Research the effects of torsional friction on rolling objects
  • Learn about the moment of inertia and its impact on friction calculations
  • Explore advanced topics in dynamics, specifically on inclined planes
  • Study the principles of static and kinetic friction in greater detail
Students studying physics, particularly those focusing on mechanics, as well as educators and anyone interested in understanding the dynamics of friction in practical experiments.
JackSac67
I have a question regarding a friction experiment, so here's what I have so far:
Calculate the approximate force of friction between the wheels of a cart and a ramp it is rolling on by only using the cart's mass and different values of acceleration up and down the ramp. Here was the general procedure used to collect the acceleration data:
1. Hold cart at rest directly before the sensor on the ramp that will calculate acceleration, then give it a little push so it rolls up the ramp past the sensor. Do this five times and average the value of deceleration.
2. Hold cart at rest directly above the sensor on the ramp that will calculate acceleration, then let it go so it begins rolling down the ramp and past the sensor. Do this five times and average the value of acceleration.
Cart's mass = .265kg
Cart's acceleration on the way down the ramp = .369m/s^2
Cart's acceleration on the way up the ramp = -.435m/s^2
By choosing the acceleration of the cart down the ramp as the positive direction:
ƩFx as the cart rolls down the ramp = .265(9.8)sinθ - Ff = .265(.365)
ƩFx as the cart rolls up the ramp = .265(9.8)sinθ + Ff = .265(-.435)
Subtracting the bottom equation from the top equation yields:
-2Ff = .265(.804)
Ff = -.107N (Rounding to significant figures)
Now my question deals with that resultant friction force. I was confused as to why the force came out negative, but unless I made an error somewhere, I think I have an idea as to why. Because the wheels of the cart and the ramp never changed, the coefficient of friction between them stayed constant. And because the mass of the cart never changed, the normal force exerted on the cart stayed the same, and thus there is a constant normal force and coefficient of friction during both runs of the experiment, so the friction force in both runs of the experiment was the same. Because of this fact, must I consider Ff between the ramp and cart as |Ff|, i.e. the sign doesn't matter in this context? This would make sense to me, because I would expect an very small force of friction to act on small, smooth wheels of a cart. If anyone can confirm or help me understand this better, that would be greatly appreciated, thanks.
You have some sign errors. For gravity, you have consistently put down as positive, which is fine. But your two acceleration measures are taken in opposite directions. Clearly, the actual acceleration was positive down ramp in each case, but you are showing the up ramp acceleration is negative, so it must have been measured in the direction of movement. Correct the sign of that and you will find the frictional force is positive.
Btw, the question is misleading. Even if the two accelerations were the same there would be a frictional force on the wheels from the ramp, but it would be directed up the ramp and be of equal magnitude in both cases. (With no friction, the wheels would rotate at constant speed.) The reason they are not the same is torsional friction at the wheels' axles. If the torsional friction is τ and the wheels' radius is r, this leads to an extra frictional force at the ramp of τ/r, opposing direction of movement of the cart.
So the frictional force between ramp and wheels is:
- without torsional friction: F, always up the ramp
- with torsional friction, going up: F-τ/r up the ramp
- with torsional friction, going down: F+τ/r up the ramp
What you are calculating is τ/r (multiplied by number of wheels).
The magnitude of F depends on the moment of inertia of the wheels.
Ah, I see now. I forgot I had to keep the direction of acceleration consistent for both equations. In that case I found Ff to be approximately .009N, which certainly makes more sense as a friction force between a smooth ramp and small smooth wheels. I understand what you're saying in regards to the torsional friction, but my class hasn't yet talked about these forces.
