Question on Conservation of Momentum
The discussion revolves around calculating the height a top ball will bounce in a toy that utilizes conservation of momentum and potential energy. The user has recorded potential energies and the masses of the balls but struggles to find the right equation for predicting the bounce height. A proposed solution suggests that the top ball could rise to five times the initial drop height, based on assumptions about the deformation of the balls during collision. The calculations involve ratios of the balls' radii and conservation of mechanical energy. Overall, the complexity of the interactions among multiple balls complicates the calculations, but the toy appears to function as intended.
agentorange812
So I have one of these trippy toys
http://www.spacehall.com/shop/images/AstroBlaster.JPG ,[/URL] and have a question.
Basically the way that it works, is that all the balls bounce, and the top one that isn't secured on rockets off very high while the others are secured in place on a rod. I know that this is because the combined mass is exerted upon the small top ball (Potential Energy = mass*gravity*height, thus the combined mass means that it has a huge potential energy).
Anyways, my question is that if I have recorded all the data about it, know the elasticity of the top ball, and have the potential energy calculated. Is there any way to calculate how high the ball will bounce if I know the potential energy?
(The potential energies for the entire thing and just the top ball are ~5000 and 200 J respectively)
Potential Energy = MassGravityHeight , Kintetic Energy = 1/2 MassVelocity^2
So far I have tried to divide the PE's and find a ratio, however the balls bounce at about 50cm and 3.8cm combined and just the top ball, but the ratios don't work out right.
Did you try a Google search on this. I'm sure I have seen the whole thing worked out more than once.
I'm not finding it now though. Do you know the masses of the balls?
the masses are --
3.88g for the top ball
9.96 for the next bigger
23.15 for the next bigger
64.11 for the next bigger
and 101.1g total
Dropped from 5cm, the top ball bounced an average of 52cm
Yeah, I tried googling it... haven't had any luck though. This SHOULD be really easy... I just can't find the right equation or am missing something!
agentorange812 said:
the masses are --
and 101.1g total
Actually, I don't think it is easy. When you have that many objects involved in a process things get complicated in a hurry. I have come up with a solution based on an assumption that may not be completely valid, but it does lead to the conclusion that the top ball will rise to five times the initial height from which the blaster is dropped. The "five times" number is quoted in all the product descriptions I have seen.
The assumption is that each ball deforms in proportion to its radius, and that the balls remain in contact with one another while they are compressed. That means the top ball moves farther than the bottom ball during the collision process. Imagine the balls all being compressed by some fraction of their radius at the lowest point in the collision, with the center of mass being half way between the top and bottom of each ball. Let's number the balls 1 through 4 from top to bottom and call the distance the bottom ball CM moves d4 = kR4. The CM of the next ball up moves d3 = k(2R4 + R3). The next will be d2 = k(2R4 + 2R3 + R2) and finally d1 = k(2R4 + 2R3 + 2R2 +R1).
Assuming the balls all move together, the velocity of each ball at the end of collision will be proportional to the distance it moved up from the lowest point during the collision. To find those distances, you need the ratios of the radii. I calculated those assuming solid balls of the same density, which is not quite right because of the holes even if they are made of the same material. Using the velocity ratios from this calculation, I assumed all the mechanical energy was conserved and calculated the height each ball would reach if they were all free to move separately. (It looks to me from the picture that they can all separate a bit before the middle two get stopped by the stick) Then I took the total momentum of the bottom 3 balls and treated those as having a secondary collision that keeps them connected as one object.
The result of this calculation is that the top ball bounces just over 5 times the drop height, while the bottom three ball combination bounces to about 0.61 times the drop height.
Do you mind telling me where you got one of those trippy toys. Looks like a bit of fun
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 19 ·
  • · Replies 29 ·
