Question on flow rates over a weir.
  • Thread starter Thread starter jason_mcc
    Flow
The discussion focuses on calculating the width of a rectangular notch required to achieve a specific discharge rate of 0.14 m3/sec at a water level of 0.23 m. The initial equation used was incorrect due to a typo in the exponent of H, which should be H1.5 instead of H0.66667. After correcting the equation, the correct width of the notch is determined to be 0.716 m.
  • Understanding of fluid mechanics principles, specifically flow over weirs.
  • Familiarity with the equation for flow rate over a rectangular notch.
  • Knowledge of the coefficient of discharge (Cd) and its application.
  • Basic algebra skills for solving equations.
  • Study the derivation of the flow rate equation for rectangular notches.
  • Learn about the impact of the coefficient of discharge on flow calculations.
  • Explore different types of weirs and their applications in hydraulic engineering.
  • Investigate the effects of varying water levels on discharge rates in open channel flow.
Students in civil engineering, hydraulic engineers, and professionals involved in water resource management who need to calculate flow rates over weirs.
jason_mcc
Hi everyone. All help is appreciated.
The discharge over a rectangular notch is to be 0.14m3/sec when the water level is 0.23m above the sill. If the coefficient of discharge is 0.6 calculate the width of notch required.
Answer: 0.716m
I think it is Q=\frac{2}{3}b\sqrt{2g}H^{\frac{2}{3}}Cd
where Q=flow rate, H=height of water level above bottom of notch, b=width of notch.
0.14=\frac{2}{3}b\sqrt{2g}0.23^{\frac{2}{3}}0.6
0.14= 2/3 x b x 4.429 x 0.375 x 0.6
0.14= 0.664 b
b= 0.21m
which is wrong. Anyone know what I'm doing wrong?
jason_mcc: There is a typo in your given relevant equation. Change H^0.66667 in your relevant equation to H^1.5.
Thanks, got it now.
  • · Replies 25 ·
  • · Replies 16 ·
