- 29,728
- 21,575
The answer is B whether you use the Lorentz force law or the Fleming rule.physicals said:here's the deal, if you can prove the answer is B using high school physics then I will send the examiners report
The discussion revolves around the motion of a charged particle in a magnetic field, specifically addressing a past exam question where the original poster's answer contradicts the provided mark scheme. The subject area includes concepts of magnetism, circular motion, and the application of various hand rules to determine the direction of forces and fields.
The discussion is ongoing, with participants presenting differing views on the correct answer to the exam question. Some suggest that the mark scheme may be incorrect, while others defend the provided answer. There is a mix of reasoning and questioning of assumptions, particularly regarding the application of hand rules and the nature of magnetic fields.
Participants note that the question may not align with the expected knowledge level for high school students, raising concerns about the complexity of concepts like the Lorentz force law and the application of multiple hand rules. There is also mention of the need for a clear distinction between the magnetic field generated by the charge and the external magnetic field in the context of the problem.
A force is a force. A force of constant magnitude that is always perpendicular to the velocity results in circular motion.physicals said:so the magnetic field pushes the particle instead of pull? then how is there circular motion?
