Question on static int variable
  • Thread starter Thread starter yungman
    Static Variable
13 replies · 1K views
yungman
I don't understand this header file in the book. In line 4, it declares static int objectCount;
I tried to put static int objectCount = 0; it won't compile, I tried putting in the next line objectCount = 0; it doesn't work. I tried putting in line 6, it doesn't work.
Being declare in private, obviously Tree::objectCount = 0 in main() won't work.
Then the book put that in line 11 OUTSIDE the Class definition, it works.
I don't understand any of this, can anyone explain to me. What is the statement in line 11 called?
C++:
class Tree
private:
static int objectCount;//Static member variable
public:
    //objectCount = 0;
    Tree() { objectCount++; }// Constructor
    int getobjectCount() const { return objectCount; }
#endif
int Tree::objectCount = 0;
Thanks
Being declare in private, obviously Tree::eek:bjectCount = 0 in main() won't work.
C++:
class Tree
private:
public:
    //objectCount = 0;
#endif
Thanks
A static member variable is shared among all instances/objects of a class, and exists independently of those instances. C++ has a rule that says you can only define something once and because of some complicated issues that I won't try to explain, it means that non const static member variables need to be initialized in the cpp file, which is a single computational unit (otherwise if it's in the header, it would be like the one variable is being set multiple times, like if the header was included in multiple files).
C++:
class Tree
private:
public:
#endif
In the cpp file
C++:
Alternatively, you could not use a static variable. I don't think it's a great idea. What if you wanted to have multiple different trees? You would have both trees sharing the same count, which wouldn't work.
The better way to make a tree is make a Tree class and a TreeNode class like in this pseudocode.
C++:
class Tree
    int nodeCount;
    struct TreeNode {
    int nodeCount
    TreeNode root;
#endif
There is one use case for static non-const member variables that I've needed sort of. Which is for giving each object a unique numerical id. In that case, the static variable holds the next id to assign. Each time an object is constructed it gets the next id and the next id is incremented.
C++:
class Tree
private:
public:
#endif
In the cpp file
C++:
C++:
class Tree
    int nodeCount;
    struct TreeNode {
    int nodeCount
    TreeNode root;
#endif
Thanks for the reply, what I don't understand is compiler flag me error when I do this:
C++:
class Tree
{  private:    static int objectCount = 0;
I defined it the first time in one statement. Still it won't work.
I did not realize you can define Tree:ObjectCount = 0; outside the header file after it is declared private. This is why it's so confusing. It's almost like they make up their own rules on-the-fly.
So even if the variable is declared private, I can write Tree:ObjectCount = 0 in Implementation file? Then how come I cannot do it in main()? Now we are going in circle.....Private supposed to mean nobody can change it outside of header file, BUT you can change it in .cpp (Implementation) file...BUT you cannot change it in source.cpp file! I am missing something here.
ThanksHow come I get that funny thing every time I type o?
C++:
class Tree
Thanks
It has nothing to do with private. It's a special case for static member variables. You can't assign it in the header file, so that's why you get a compiler error.
And the rule makes sense. Actually no member variables (except static const) can be assigned outside of the member functions. The constructor is for initialization. But the constructor is called for each object. So you would have the same variable being initialized multiple times, which doesn't make sense. They could have made it work, but they have a sort of strict mindset to make everything be logically sound on the surface.
So if there is any static variable, I have to assign in Implementation file. OK, I'll write it down in the notes.
I know about not to use static variable if possible, this is in Chapter 14 on Static Member and Instance Member. I have no choice but to study through it. Life is hard already, why set up more booby traps to fail?
Thanks for you time.
Static variables are defined for the class itself not for the instances created by the class. Where they come in handy is when you have some common variable for all instances like a global in non C++ C code.
I‘ve used it to keep a count of instances as they are created and destroyed. I’ve also used it for common constants across all instances of a class.
here’s some more info online
https://www.tutorialspoint.com/cplusplus/cpp_static_members.htm
Yeah.
It has some use cases. Like I said, I used static member variables sometimes. You have to think if you actually need a single variable shared amongst all instances of a class or not, and realize the consequences of it.
It's actually every time you type :O
It's interpreting : O as an emoticon and converting it to an Emoji.
This is what the [ code ] tag is for. It will prevent such interpretations.
  • Haha
That's exactly what the program in the book does, keeping track of how many instance of the Class there are as it puts the variable in the Constructor so every Instance will call the constructor and increment the count.
thanks
oh no, no o!
I fixed @yungman posts with the emoticon by replacing it with an O again.
jedishrfu said:
oh no, no o!
The link you gave on the tutorial is MUCH better than the book. I am actually going to use it in my notes for demonstration.
Thanks
I'm trying to figure out the use case for a non-const static variable initialized in the header. As pointed out, one can use a non-const static to keep track of the number of instances of a class, but this won't work if you keep setting it to zero again every time an object is created.
I confess that I didn't know C++ forbade this. I had no cause to even try it. What would such a thing be good for?
One could use a static counter and if it’s zero then initialize static stuff in your constructor before incrementing the static counter. This would insure that there's no resetting of the other static data.
So, for example, if you wanted to store the time that the first object of a given class was created, that would be a way to do it (if the language allowed it).
I can sort of see that, but I would be strongly inclined to use a mutator instead. I don't like logic in constrctors if it can be avoided. If something goes wrong, the constructor can't tell you.
