Question on the error function and when I can evaluate it numerically
  • Thread starter Thread starter trmcclain
    Error Function
The discussion revolves around the integration of a complex mass model function involving the error function (erf). The user seeks clarification on whether it's mathematically valid to extract erf(x) from an integral since its value is known for any finite x. Responses clarify that this extraction is incorrect, drawing parallels to other functions like sine and cosine, which cannot be simplified in that manner. For numerical integration, methods such as Simpson's Rule or Gaussian Quadrature are recommended, especially for stochastic simulations. The conversation emphasizes the importance of using appropriate numerical techniques rather than attempting to derive a closed-form solution.
trmcclain
I'm working with a particularly malicious mass model function given as:
λ^n*exp(-x^2)*(λ+x)^-n, λ=constant, n=constant (1.8 for those who care)
The first round of integration by parts using
u=(λ+x)^-n, du=-n(λ+x)^(-n-1)dx
dv=exp(-x^2), v=sqrt(pi)/2*erf(x)
Gives me:
(λ+x)^-n*[sqrt(pi)/2]*erf(x) + [n*sqrt(pi)/2]*∫erf(x)*(λ+x)^(-n-1)dx
Now I know for any given value of x, the erf(x) has a known value. C++ even has a function for it.
My question is, is it good math to utilize the fact that erf(x) for any finite value is known and constant to pull it out of the integral? Or do I need to utilize a different integration technique to solve this equation?
For anyone interested, I am trying to use this equation as a probability density model to randomly scatter points.
I'm not sure what you are asking here. It certainly is correct to "look up" the value of erf(x) or use computer function for it, just as you can use tables of trig functions or logarithms or use functions on a calculator or computer languages.
My question is can i use that value for the erf(x) in order to take it out of the integral. If not, then I have to integrate it which will cause many headaches...
To answer your question in a nutshell, no.
sin(x) and cos(x) and several other functions also meet your criterion that they evaluate to a constant for any value of x. Yet it is not true to say that
Int (sin(x) dx) = sin (x) * Int dx = x * sin (x)
Int (cos(x) dx) = cos (x) * Int dx = x * cos (x)
which are obviously wrong.
Some integrals do not have a closed form solution in terms of other elementary functions.
Look at a copy of Abramowitz & Stegun: http://people.math.sfu.ca/~cbm/aands/toc.htm
There are several definite integrals tabulated here [one of which is erf (x)] which have no representation in terms of the elementary functions but for which values can be tabulated.
Gives me:
If you are asking whether
\int \text{erf}(x) (x+\lambda)^{-n-1} \, dx
equals
\text{erf}(x) \int (x+\lambda)^{-n-1} \, dx the answer is NO! Never, never, ever assume something like that!
Firstly - damnit. When you bring up trig it sort of slapped me in the face that of course I can't do that.
Secondly - awesome resource. But my problem remains.
If I try to perform a definite integral on the erf(x), not only does a gaussian appear, but also another erf(x) this time with an x multiplying in.
Would this not repeat ad infinitum the more I apply integration by parts?
equals
I realize this now, and I am glad that I asked first before just rolling with it.
Bump for more help.
If I must perform a definite integral on erf(x)*f(x), and I don't want to do an infinite number of integration by parts (I really don't have the time), than what is the next step?
Do you need a closed form solution of this integral? It seems like numerical integration is probably sufficient if you're just going to run stochastic simulations for example
Closed form in the sense of finite, yes. The equation is part of a probability density which I am using to scatter particles randomly using Newton-Raphson's Method. In order to do that, the function must be integrated from 0 to a finite upper limit.
You will have to use some kind of approximation, and this might mean breaking up the integration range, using different approximations in different ranges. E.g. for x small compared to lambda, you can expand the (x+λ)−n term binomially.
Your integral can be evaluated numerically. For your particular integrand, either Simpson's First Rule or a Gaussian Quadrature would probably give good results.
The Simpson's Rule would require that the interval of integration be divided into an even number of subdivisions, where n >= 2, and the integrand would be evaluated at each point within the interval and at the endpoints.
The Gaussian Quadrature method uses a set of irregularly spaced abscissa locations within the interval of integration. Once the function ordinates are obtained, a set of weighting factors is applied to determine the value of the integral.
Simpson's Rule is explained here: http://mathworld.wolfram.com/SimpsonsRule.html
Gaussian quadrature here: http://pomax.github.io/bezierinfo/legendre-gauss.html
If these don't explain things well enough, there are many other articles online. A careful search will also turn up program code which implement these methods.
Thank you for this. It happens that my n=1.8. Does this rule out Simpson's Rule?
I suspect SteamKing was using n to stand for the number of intervals.
*facepalm* Got it.
  • · Replies 17 ·
  • · Replies 28 ·
