Question on VO(acac)-piperidine
  • Thread starter Thread starter warenzeichen
The discussion centers on the differences in V=O stretching frequencies between VO(acac)2 and VO(acac)-piperidine. The lower frequency observed in the latter (957 cm^-1) compared to VO(acac)2 (995 cm^-1) is attributed to resonance effects. When piperidine is involved, it can form a bond with vanadium, resulting in a more stable nitrogen cation compared to the carbocation formed when an oxygen bonds in VO(acac)2. This stability leads to a weaker V=O bond in the piperidine complex, thus lowering the stretching frequency. The participants also discuss the bonding structure, noting that in VO(acac)2, there are effectively four bonds due to resonance between the acetylacetonate ligands. Additionally, there is a request for clarification on whether the reported stretching frequency is experimental or from literature.
warenzeichen
I am curious of the reason why the V=O stretching here has a lower frequency than that in VO(acac)2. Is it related to resonance? I am not sure.
Chemistry news on Phys.org
Yeah, you can explain it in terms of resonance.
Basically (ignoring the two existing bonds to vanadium) you have V=O <--> -V-O- where in the latter case, some ligand forms an additional bond to the vanadium atom, creating a cation somewhere else.
In the case of VO(acac)2, an oxygen forms an additional bond, leaving a cation on the carbon it is bonded to. With piperedine, the nitrogen can form a second bond to vanadium, with its lone pair, making the nitrogen a cation.
The nitrogen cation is more stable than the carbocation, so the V-O- resonance form is more stable with piperidine, so the V=O double-bond is weaker, so the V=O stretch has a lower frequency.
(Updated: I did a calculation, it's a pretty small shift, about 20 cm-1? http://i38.tinypic.com/25z5pwg.gif")
about 40 cm^-1
the V=O stretching vibration for VO(acac)2 at 995cm^-1 and for VO(acac)-piperidine it is at 957cm^-1
I think there should be four bonds except the V=O ? also, one acac is substituted by piperidine, isn't it?
Thanks.
warenzeichen said:
about 40 cm^-1
Well, close enough - well within the margin of error. :)
Well, with VO(acac)2 you'll have four oxygens liganding, but with two bonds which you could view as resonating between the two acetylacetonate oxygen atoms. So, 'half' a bond to each oxygen would really be a better way of thinking of it. (and in the zwitterion-resonance form, you'd have two full bonds to one acac, and a carbocation on the same acac) With VO(acac) you'd replace one acetylacetonate with the piperidine (CH2)5N-.
Thanks for your answer.
and finally could you tell me how to calculate it ? It seems that I can not calculate it based on the information I knew in the IR( I don't learn the IR on metal in details... But it looks pretty similar to IR but in more complex way...)
warenzeichen said:
about 40 cm^-1
Thanks.
Hello there,
The stretching frequency of v(V=O) band is 957 cm^(-1), could you please tell me if it is your experimental value or literature value?
Thanks
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
