Fenyman Lectures Question
  • Level: Undergrad
  • Thread starter BernardIE5317
5 replies · 421 views · last reply
BernardIE5317
TL;DR
"5–6 Large distances" how to measure relative distances of the planets ?
greetings & kind regards
may i please request assistance understanding a sentence from a page of "The Feynman Lectures on Physics, Volume I" link below :
https://www.feynmanlectures.caltech.edu/I_05.html
section titled : "5–6 Large distances"
paragraph Immediately below Fig. 5–4 beginning w/ "We cannot do the same with the sun, ..."
the sentence in question which i do not understand and seek assistance in fuller explanation is : "We measure the relative distances of all the planets by astronomical observations of where the planets appear to be, and we get a picture of the solar system with the proper relative distances of everything, but with no absolute distance."
my confusion results for several reasons :
[0] : i do not know origin of the relative distance referred to though i presume it is an Earth based observer but am not certain as perhaps it can also refer to relative distances betwixt and between the planets or perhaps wrt/ to Sun .
[1] : i do not know means by which said relative distances are measured .
thank you most kindly
cheers
This is always a problem in astronomy. When we measure the position of an object on the sky, like a planet, we measure what direction it is, but we don't know how far away it is. So when we measure the locations of the planets on the sky, we get a model of the solar system, but we don't know its absolute size. To get the size of the solar system, we have to add some other information.
As to how the locations of the objects on the sky are measured, perhaps the easiest way to understand is to look at how Tycho Brahe in the 16th century compiled his catalog of planetary positions that allowed Johannes Kepler to understand the orbits of the planets. In the attached sketch of Tycho's armillary sphere, the gray axis of rotation (labeled B) was aligned parallel to the Earth's axis. Then, by sighting along the movable arms (the one labeld F, for example), you could measure the direction of the object you are interested in. Today's instruments are of course more sophisticated, but the concept is the same.
Feynman was being rather vague here, but I think he was possibly referring to using orbital mechanics to get relative distances which could then be locked down using an absolute measurement of the astronomical unit (AU).
Kepler's third law gets you the semi major axis of any orbit as a function of orbital period. You can compare planetary orbit periods to the Earth's, add in eccentricity information, and get a distance in terms of AU. But the AU itself must be measured and it's hard to do so via triangulation.
The other possibility is he just means things in a general sense; that many long distance measuring strategies give only relative distances and we need at least one absolute distance to pin things down.
If we use the Earth as a baseline for triangulation, you have the absolute distances here on Earth, e.g. by measuring the Earth's diameter using shadows, to tie things down. But if you try to use the Earth's orbit for triangulation (which we do for nearby stars) then you need, again, to know the AU.
Matterwave said:
Feynman was being rather vague here,...
Not Feynman; Matthew Sands gave this lecture, and also the following one on probability, while Feynman was away for a week.
BernardIE5317 said:
TL;DR: "5–6 Large distances" how to measure relative distances of the planets ?
Earth based observer.
I did a google search for "measure relative distance to planets" and found several easy to understand answers to your question
