- 42,978
- 10,571
You really must try to be less vague. Must exist in where? If you mean within an mbc then you should have written "If all the vertices of an mbc ..."Superyoshiom said:If all the vertices of the mbc's are even then there must exist in there a cycle
And mere existence of a cycle isn't going to get you far. It is crucial (if using this approach) that the set of edges can be decomposed into disjoint cycles.
The rest of that paragraph doesn't seem to go anywhere. How does it lead to all the vertices in G being even?
No, they need not be cycles but can be decomposed into a disjoint union of cycles.Superyoshiom said:all connected graphs with even degrees are cycles
You are taking G to be a graph for which the proposition is true. The inductive step should be showing it is true for some larger graph. The right way is to start with something like "suppose the proposition is true for all graphs up some number of (vertices or edges or mbcs ... probably doesn’t matter which you choose). Let G be a graph with one more but does not satisfy the proposition ". Then you consider removing something from G such that the reduced graph doesn’t satisfy it either.Superyoshiom said:if G is a collection of biconnected components with even degrees, ...
then if we remove an even number of edges
