Question regarding electromagnetic interaction
The discussion revolves around a physics question regarding electromagnetic interactions, specifically the behavior of accelerated electrons and their effects on a charged plate. The initial query seeks confirmation of the downward force experienced by the plate due to the accelerated electrons. Participants clarify that while there is a non-oscillating electric field directed along the acceleration, there is also an electric field that exerts a lateral force on the plate. The distinction between the decay rates of these fields is noted, with one diminishing as 1/r and the other as 1/r^2. The conversation concludes by emphasizing that the charge in question does not oscillate, thus radiating a non-oscillating field.
Lory73
Hello
I attach a question (PDF-file) which I found in an old physics book, I printed the question and re-generated the drawing which were a bit hard to scan.
Can anyone answer the attached question, I think I know the answer but I want to be sure.
Thanks
Lory
Tell us what you think the answer is, and your reasoning, and then we can either confirm it or rip it to shreds. :biggrin:
Well, the obvious answer is that the plate experience a force downward.
The thing that puzzles me is whether the accelerated electrons are suppose to generate an ossilating electric field to both diretions (up and down) or a unidirectional electric field due to the fact that they are only accelerated in one direction.
Now, am I right ?
There will be a non-oscillating electric field E_a in the direction of the acceleration, exerting a downward force on the positively charged plate, as you say.
There will also be an electric field E_b pointing toward the electron, which would exert a leftward force on the plate. E_a falls off as 1/r, while E_b falls off as 1/r^2, so each will dominate at different distances.
An oscillating charge radiates an oscillating field, but this charge is not oscillating.
Thanks Pam
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
It may be shown from the equations of electromagnetism, by James Clerk Maxwell in the 1860’s, that the speed of light in the vacuum of free space is related to electric permittivity (ϵ) and magnetic permeability (μ) by the equation: c=1/√( μ ϵ ) . This value is a constant for the vacuum of free space and is independent of the motion of the observer. It was this fact, in part, that led Albert Einstein to Special Relativity.
