Undergrad Question regarding Stokes' Theorem
  • Thread starter Thread starter Laudator
    Stokes Theorem
Stokes' Theorem establishes the relationship between the surface integral of the curl of a vector field and the line integral of the vector field itself. Specifically, if the right-hand side (RHS) integral equals zero, it does not necessarily imply that the curl of the vector field, denoted as ##\nabla \times \mathbf v##, is zero everywhere. The discussion emphasizes that the integral must vanish for all possible regions of integration to conclude that the function is zero everywhere, and continuity of the function aids in proving this assertion.
  • Understanding of vector calculus, specifically Stokes' Theorem
  • Familiarity with the concepts of surface integrals and line integrals
  • Knowledge of continuity in mathematical functions
  • Basic proficiency in mathematical proofs and reasoning
  • Study the formal proof of Stokes' Theorem in vector calculus
  • Explore the implications of continuity on integrals and differentiability
  • Learn about the properties of curl and divergence in vector fields
  • Investigate examples of Stokes' Theorem applied to various vector fields
Students and professionals in mathematics, physics, and engineering who are studying vector calculus and seeking to deepen their understanding of Stokes' Theorem and its applications.
Laudator
Stokes' Theorem states that:
$$\int (\nabla \times \mathbf v) \cdot d \mathbf a = \oint \mathbf v \cdot d \mathbf l$$ Now, if for a specific situation, I can work out the RHS and it's equal to zero, does it necessarily mean that ##\nabla \times \mathbf v = 0##? I mean all that tells me is that the surface integral on the LHS is zero and integrals are like infinite summations, could all those tiny ##(\nabla \times \mathbf v) \cdot d \mathbf a## magically cancel each other (for any arbitrary surfaces, not just one specially chosen) yet left ##\nabla \times \mathbf v## none zero? And if this possibility doesn't exist, how to prove it?
Follow up: Found an answer on StackExchange says “... if the integral vanishes for all possible regions of integration, then the function is zero everywhere.", he also pointed out the formal proof of this is not easy. So I guess at my level, I should settle for this.
You have to distinguish the case that an integral is zero for a particular region, surface or curve and the case where it is zero for all regions, surfaces or curves.
The proof shouldn't be too hard if you assume continuity of your function.
  • · Replies 26 ·
