Question relating Newton's First Law of motion
Newton's First Law of motion states that an object in motion will remain in motion with a constant velocity unless acted upon by an external force. In the context of a space shuttle in outer space, once the engines stop functioning, the shuttle will continue to move at its current velocity indefinitely, as there are no opposing forces like friction or gravity to slow it down. This principle contrasts with everyday experiences on Earth, where friction and gravity are always present, leading to the misconception that objects must stop when a force is removed. Historical insights from Galileo further clarify this understanding, emphasizing the importance of recognizing the absence of forces in space.
  • Understanding of Newton's Laws of Motion
  • Basic knowledge of forces and motion in physics
  • Familiarity with concepts of gravity and friction
  • Awareness of orbital mechanics and satellite dynamics
  • Study the implications of Newton's First Law in various environments, including space.
  • Explore the role of friction in everyday motion and its absence in space.
  • Research orbital mechanics and the behavior of satellites in low Earth orbit.
  • Learn about the engineering techniques used by NASA to minimize friction in experiments.
Students of physics, aerospace engineers, educators, and anyone interested in understanding motion in space and the principles governing it.
ehabmozart
Hi there! I kept on reading my textbook and i found one simple confusion in Newton's First law of motion. I want to consider a situation where a space shuttle is moving in the outerspace (assume there is no gravity) under the influence of the engines. What will happen when the engine stops functioning? It is given that the space shuttle will move with a constant velocity. Now, my opinion would be that there was an initial forward force given by the engine, no it is taken off. Is is like pulling the space shuttle. So it ultimately must end up by a stop! This is confusing me. I would really be thankful to whoever helps me in clarifying my confusion. Thanks in advance. I need elaborate answers if u please :)
Science news on Phys.org
The intuition that once you stop the force the object will stop is an illusion produced
by the fact that we grow up in an environment where there is friction everywhere. When we stop pushing an object, it may only move a short distance before friction slows it down to a stop. But friction is also a force. If no force at all, including friction, acts on an object, it will move with a constant velocity forever. The ancient people, even the most educated, believed the idea that seems like common sense but is incorrect -- until Galileo figured out the real answer in the 1600s.
space is a fun place to do physics because we are allowed to make up situations that we normally couldn't do on earth.
So let's say you are going in your shuttle off Earth into space and at t=20 your engine turns off, and you get past Earth's gravity, you are in free floating space. you could then just keep on going that same speed for ever and ever until you bumped into something, or near something real big. (I think we have satelights pointed at us sending information that use no fuel to keep on going. Because there is no need)
Thinking it would slow down is common sense nowadaysz because if your rolling down the street on a scooter eventually your going to slow down. There are so many different frictions to think about when on a scooter that we take for granted. The fact that there is air that is trying to get around us slows us down, plus friction between the wheel and the ground, and then the wheel bearing.
yup it sure is we can only sort of create the conditions of Newtons first law of every action has an equal and opposite reaction
At NASA they use smooth floors and have air cusioned units that will glide over the surface with a minimal amount of friction its a very good approximation :)
very difficult to get away from the effects of Earth's gravity. You much be a VERY long way away. Remember that even in orbit satellites, shuttle and its astronauts are in a constant state of freefall due to gravity
Satellites do have small rocket thrusters ( usually just gas exhausts) these are there to periodically boost the satellite's orbit. Most satellites (in lower Earth orbit regions) are not that far above the Earth's atmosphere and the small amount of resistance from that and loss of orbital velocity means they do slowly loose orbital height and need the occassional boost to get them back in position.
The life of the satellite comes to an end when there is no more propellant on the satellite to do the boosts in orbit and then they are on that inevidable spiral back into the atmosphere and burn up
Dave
When you stop accelerating an object, it will continue to move at the velocity it had before.
For example, say I had a rock and attached a string to it, then went and spun the rock with the string (Think David and Goliath),after a while the string snapped and ceased to pull on the rock, the rock will fly out tangent to the circular trajectory it used to be on.
  • · Replies 16 ·
  • · Replies 41 ·
