Questions about molec. geometry and electron pairing
  • Thread starter Thread starter adamc637
    Electron Geometry
Triamminetetrachloroplatinum(V) ion (Pt(NH3)2Cl4 +) cannot adopt a hexagonal planar geometry due to steric repulsion between the hydrogen atoms on the amines, leading to a pentagonal pyramidal structure instead. The discussion highlights that there are three possible geometric isomers for this ion, but the repulsion ultimately influences its geometry. Additionally, the increase in melting points from group IIIB to VB or VIB is attributed to unpaired electrons, while paired electrons in group VIB and higher result in lower boiling points. A resource was shared to assist with understanding molecular geometries, which proved helpful for studying. Understanding these concepts is crucial for grasping the behavior of transition metal complexes.
adamc637
I have 2 questions which I'm just pondering because I can't answer them
First is
If triamminetetrachloroplatinum(V) ion (Pt(NH3)2Cl4 +) were to be put into a hexagonal planar geometry, how many geometric isomers would it have? Is it possible to have this arrangement or not from what you see from the drawings?
I drew them out, and I can't think of why it would rule hexagonal planar out other than being polar and the molecules pushing it away (which doesn't sound too plausible anyways).
Second question:
In the case of transition metals, going from group IIIB to group VB or VIB, the melting point gets higher because "the electrons are not paired". Why does having paired electrons in group VIB and up cause the boiling point to fall?
Chemistry news on Phys.org
draw the molecule out and you will see that there are 3 possible isomers.
however, the hydrogens on the amines will repel each other and you will wind up with a pentagonal pyramidal structure.
I think this website should help you . . .
I had a huge test on molecular geometries not too long ago. I was having a lots of difficulty with them, but then I found this great website that has a link for every geometric shape and with it examples, pictures, and important notes. The website is http://intro.chem.okstate.edu/1314F00/Lecture/Chapter10/VSEPR.html. I hope it helps you, I know it really helped me. Good luck!
11K
14K
  • · Replies 16 ·
  • · Replies 35 ·
  • · Replies 60 ·
