Questions about Newton's third law
60 replies · 20K views
Well, I could try and simplify it to that... but...
I read up a bit on that drag stuff, doesn't seem too bad...
But if you can measure the drag on the car, that only gives you force applied to the car, and thus the force the car applies to the air.
I know doc al said that the air cannot be considered to have a point mass, but can't you at least estimate how much air you're dealing with here? I don't really need any complicated equations or anything yet, but I'm just curious as to how you could roughly estimate this, if the air is applying a force, surely there must be some mass you are dealing with?
The aerodyanmic drag is mostly due to acceleration of the air in the direction a car is moving. Assuming that the car isn't streamlined with a long tapered tail like a bonneville speed car, most of the drag occurs behind the car, because the car leaves a moving void behind it that creates a low pressure area that accelerates the air towards it. So this part of the drag is due to the old force = mass times acceleration.
Another component of aerodynamic drag is due to friction which increases the temperature of the air. I don't know how much of a part this plays in overall drag, but I suspect it's not much.
Trying to estimate the amount of air involved would be difficult, as there are different amounts of acceleration applied to the volume of air affected by a moving vehicle.
Regarding the air accelerating a car; if the car was very easy to move, then a strong breeze (headwind or tailwind) could move such a car.
Ok, but I don't think my question has been answered... I know generally how drag works, but what mass of the air causes this? As said before, I know the air isn't reall a point mass, but if it's exerting a force, than, as I said, surely it has some mass?
I think the problem isn't that there is no mass, but that it's ridiculously hard to calculate the mass that's involved. The air molecules, because they act like a fluid, work together. We don't know how many molecules are working together, so it's hard to estimate the mass that's involved.
You can't just break it up and say "Oh, this many cubic feet are affecting the drag." You also can't say "This many molecules are causing the friction." I'm not sure, other than an educated guess, you could ever find out how much mass is involved in something like that.
Ok, now I think I understand a little better, but is it possible to estimate if the mass of the air causing the friction is greater than the mass of the car? That was basically my intention here, do we really have no idea what the mass is, or can we at least estimate it to be greater/less than the mass of the car?
If you know the power output of the car and you know its top speed its pretty easy to estimate the drag force (and hence the mass of air) present when the car is traveling at its maximum speed. This is of course, ignoring any rolling resistance of the tyres, axles, drive staft, gearbox etc. But atleast it will give you an estimate.
Err, if you have force, wouldn't you still need the acceleration to calculate mass? Or can the acceleration on the air from the car also be determined by the drag force?
If we assume that the car is a cuboid of defined volume and dimensions we could etimate the mass of air displaced.
Go to a highway and measure approximately how far away from it you can stand, and still feel the breeze from passing cars. Then you can make at least a crude estimate of the volume of air that is affected by a passing car, and from that, the mass of the air.
Ok... which one is it here, if you know the volume of the car, is that equal to the volume of displaced air? And then knowing it's density, you could calculate the amount of displaced air? Actually, jtbell's answer is probably the same here, by crudely measuring as said... you could estimate the mass. But are the volume of the displaced air and the volume of the car the same? From that you could calculate(knowing the density of the air) the mass of the air...
But would you assume the car to be denser than the air? Probably, since most of what's in the car is solid...
Also...
Farsight said:
Oh look it up on Google. Air is circa 1.3kg per cubic metre, and a car is maybe six cubic metres, so we're talking about 18 pounds in weight.
How do you approximate the 18 pounds in weight here?
These will likely be my last questions in this thread by the way, once all of this is answered, I'll post a summary of what I've learned from this thread, and then ask if it's right.
A very crude estimate of the air mass moved per unit time can be had by treating the car as a "plow" with a given area moving at a given speed, scooping out air as it goes. You can figure out the volume per second that the car "scoops" out of the way.
Ok, what volume do you use per second then, the volume of the car? And I'm still curious about how the 18 lbs was estimated, unless that relates to this in some way...
No. The rate at which volume is scooped out will equal Area x Speed. (Figure out why this is true.)
What didn't you understand about this? Someone estimated the volume of a car and then calculated the mass & weight of a equal volume of air. (Not obvious that it's relevant.)
How was the 18lbs calculated? They said something like 1.3kg/m cubed, and a car was about 6 cubic m... where did 18 come from?
Oh, and what area do you use then for the volume of air scooped out per unit time? Or is there a way to calculate this which you could show me, or even a link to a place where I could learn?
You're not from the USA or the UK, right? :smile:
One kilogram corresponds to about 2.2 pounds (mass). It's a standard conversion factor that every physics student in the USA knows (or should know). I'm not sure about the UK because they're officially on the metric system, but I think some non-metric units are still in common use.
Sometimes we are required to convert between the two, however, it is something I severely dislike
Ok... so then what was it? 1.3kg = 2.86lbs and then what? Weight was mentioned so I'm guessing that means multiplied by 9.8... which = 28.028... did I miss something??
We are taking six cubic meters of air, therefore; 6 x 1.3 x 2.2 = 17.16 lbs. Note, that pounds is a unit of mass not weight.
Yeah... but it was said 18 lbs of weight... I guess this just fits in with the popular misuse of the word 'weight'.
It's quite common to measure the "quantity" of something using either mass or weight, mixing units at will. It's OK in everyday usage, but not acceptable when doing physics.
Using standard units, a kilogram is a unit of mass. Near the Earth's surface that kilogram has a weight of about 9.8 Newtons, which is equivalent to about 2.2 pounds (force).
2.2 lbs, force? Huh? I thought lbs for mass, what just happened?
Pounds(lbs) is a unit of mass. However, pounds-force(lbf) is a unit of force or weight. One pound force is approximately 4 Newton's.
The pound is used (confusingly, perhaps) as a measure both of force and of mass.
The standard pound (avoirdupois pounds) is a unit of mass defined in terms of the kilogram. (look it up)
But it's also commonly used as a unit of force in the imperial system of units, where mass is in slugs. The weight of one slug is (w = mg) 32 pounds (force).
Don't get hung up on this unit conversion trivia!
Personally, I stick with SI units. :wink:
Pound-force? News to me, I've never heard of that, I guess that's what's meant when people use pounds when talking about pressure?
Approximately 4N is 1 lbf? How is that calculated?
1N = 1kg*m/s^2 I think... what calculation is used for getting lbf?
Right. I'd say in physics or engineering it's more common to use pounds to measure force rather than mass. But you will almost always be able to tell by the context.
I don't know what you mean by "calculated". This is a conversion factor between different systems of units. More accurately, 1 pound = 4.448 N.
That's a definition. An analogous one for pounds-force would be:
1lbf = 1slug*ft/s^2.
Oh, it uses feet as well, that's probably another thing I forgot to consider... so with ft and slug, the conversions work about to be about 4.448N? I think I've got it now
Yeah, that is correct. You have to use imperial units for acceleration.
To estimate the mass of air invovled, you need to know the amount of drag force and the average velocity of the air (assuming a no wind condition here) around a car, when the car is traveling at a specific velocity.
The amount of power due to drag is equal to the velocity of the car times the drag force of the air. For example, 1 horspower = speed in mph times force in lbs divided by 375 (conversion factor).
Using 1 second as a time factor, the work done by drag equals drag force times the distance the car moves in 1 second.
The amount of work done in 1 second will equal the amount of increase in energy, mostly kinetic, of the air in 1 second.
This is the tough part, you need to meausre or estimate the average velocity of the air affected by the car. Once this is estimated, then you can calculate the mass using the relationship between kinetic energy and mass e = 1/2 m v^2.
As an example, a 2006 Z06 Corvette, which has fairly low coeffiecient of drag, takes about 450 rear wheel horsepower to go 198mph. To make things easy, I'll assume that rolling resistance consumes about 20 hp, and that drag consumes about 430hp. This translates into a drag force of about 814lbs.
At 198 mph, the car is moving 290 feet / second. With a force of 814 lbs, the energy increase of the air is 236000 ft lbs. Assume that the average velocity of the diverted air is 30mph = 44 ft/sec, then the diverted mass per second is 244 lb mass per second or 118 cubic yards (2.06 lbs / cubic yard at sea level) of air per second. If the average velocity of the diverted air was 20mph = 29.3 ft / sec, then the diverted mass would be 550 lb mass per second or 267 cubic yards of air per second.
Need a second input here to confirm my math.
An update to my previous post. How much of the air should be considered as diverted by a car passing through it? If you include the air that increased in velocity by 1/1000th of a mph, then the amount of involved is much larger than if you only considered air that was increased in velocity by 1mph.
Somewhat related is this picture of the Thrust SST creating an enormous shock wave. Since this is super sonic (or near super sonic) speeds, the way the air is affected is different than speeds well below supersonic, but it's a good example of how much air is affected in this case:
