Questions about Partial Differentiation Operations
17 replies · 2K views · last reply
Ahmed Mehedi
TL;DR
1) If we have two functions C(y, r) and I(y, r) can we write: ∂C/∂I×∂I/∂r=∂C/∂r ? Can we also write ∂I/∂C=1/(∂C/∂I) ?
1) yes, it's the chain rule
2) In practice you often have to deal with "good" functions and it works. If you want to be super-rigorous I think you can find some examples where it is not true, but you usually do not run into such problems in physics or engineering.
Thanks a lot for your kind clarification!
Ahmed Mehedi said:
Summary:: Partial Differentiation
This is not right. The chain rule for partial derivatives requires that you have the functions defined in terms of the other variables. In this case, you must imagine that you have ##C## as a function of ##I## and ##r## and then apply the multi-variable chain rule. We can take an example:
$$C(y, r) = y + r \ \ \text{and} \ \ I(y, r) = y - r \ \ \text{then} \ \ C(I, r) = I + 2r$$
Then:
$$\frac{\partial C}{\partial I}\frac{\partial I}{\partial r} = (1)(-1) = -1$$
And
$$\frac{\partial C}{\partial r} = 2$$
Then:
And
Thanks a lot brother for your nice and concrete explanation and thanks for your time. Now, I get some insight about the problem I am facing. I have another question: In the aforementioned context is it legit to write: $$\frac{\partial I}{\partial C}=\frac{1}{\frac{\partial C}{\partial I}}$$
Then:
And
So, in this case $$\frac{\partial C}{\partial I}\frac{\partial I}{\partial r} \neq \frac{\partial C}{\partial r}$$ Then how does the multi-variable chain rule look like in this case? Again thanking you for your precious time.
That's not true for partial derivatives. Take polar coordinates:
$$x = r \cos \theta, \ \ r = \sqrt{x^2 + y^2}$$
This gives:
$$\frac{\partial x}{\partial r} = \cos \theta \ \ \text{and} \ \ \frac{\partial r}{\partial x} = \frac x r = \cos \theta$$
This gives:
Thanks a lot! Your answers are very concrete and very helpful!
@PeroK Thanks for correcting my wrong statements (for the first question I naively assumed that C was expressed as function of I which could not happen, as you pointed out), but I don't understand this
This gives:
if ##r = \frac x {\cos \theta}## and I differentiate wrt to x keeping ##\theta## constant the relation holds. What you did is differentiating wrt to ##x## but keeping only ##y## constant. And that is a different matter
dRic2 said:
@PeroK Thanks for correcting my wrong statements (for the first question I naively assumed that C was expressed as function of I which could not happen, as you pointed out), but I don't understand thisif ##r = \frac x {\cos \theta}## and I differentiate wrt to x keeping ##\theta## constant the relation holds. What you did is differentiating wrt to ##x## but keeping only ##y## constant. And that is a different matter
That's a special case where you have only three variables: ##x, r, \theta##. If we fix ##\theta##, then we have effectively a single-variable function relating ##r## and ##x##. In general, you can't simply invert partial derivatives.
The relation $$\frac{\partial y}{\partial x} = \frac{1}{\frac{\partial x}{\partial y}}$$ is generally not true, except in the case that the same variables are being held constant in each differentiation. So $$\left(\frac{\partial x}{\partial r}\right)_{\theta} = \frac{1}{\left(\frac{\partial r}{\partial x}\right)_{\theta}}$$ but as has been shown above, $$\left(\frac{\partial x}{\partial r}\right)_{\theta} \neq \frac{1}{\left(\frac{\partial r}{\partial x}\right)_{y}}$$
Well i though that It was implicitly assumed that you have to keep the same variables constant.
In thermodynamics you do this trick all the time when you deal with thermodynamic potentials and their derivatives.
I don't have much experience so I could be mistaken, but usually it is important in thermodynamics to keep track of which variables you hold constant. You can hold different variables constant without any issues. For a non-ideal gas, for instance, $$C_{V} = \left( \frac{\partial U}{\partial T} \right)_{V} \neq \left( \frac{\partial U}{\partial T} \right)_{P}$$ I would have thought it be generally incorrect to state $$\left(\frac{\partial U}{\partial T}\right)_{V} = \frac{1}{\left(\frac{\partial T}{\partial U}\right)_{P}}$$for exactly the same reasons given above.
Yes, but that Is not what I meant. In the first partial derivative you are keeping the volume constant, while in the second the pressure.
An example of what I was describing is this:
$$T = \left(\frac {\partial E}{\partial S} \right)_V$$
And
$$\frac 1 T = \left(\frac {\partial S}{\partial E} \right)_V$$
Yes that's okay, since you're holding ##V## constant both times.
Yes, that is what I was saying. I thought it was an obvious thing to assume
