Questions about vector magnitudes and angles
  • Thread starter Thread starter htk
    Vector
To find the angle between the vectors v = i + j and w = 2(i - j), the Law of Cosines can be applied after determining the lengths of both vectors using the distance formula. For the forces acting on an object, the vectors must be decomposed into their components based on their magnitudes and angles, allowing for the calculation of the resultant vector's magnitude and direction. The airplane's velocity relative to the ground requires breaking down both the airspeed and wind speed into components to find the true direction and speed. Understanding vector decomposition and the application of trigonometric functions is essential for solving these problems effectively.
htk
1) use the Law of Cosines to find the angle theta between the given vectors. (Assume 0 degree <=theta<=180degrees)v= i+ j, w=2(i - j)
My teacher told me that me that I have to find
a. length(v) = a
b. length(w) = b
c. length of vector between (1,1), (2,-2) = c. (use the distance formula.) and then use this formula c^2 = a^2 + b^2 - 2ab cos C, and solve for C but I don't know how to find length(v) and length(w).
the answer on the back of my book is 90 degrees.
2)three forces with magnitudes 70 pounds, 40 pounds, and 60 pounds act on an object at angles of -30 degrees, 45 degrees, and 135 degrees, respectively with positive x-axis. Find the direction and magnitude of the resultant.
I know that I need to find v1, v2, and v3. Then find the sum of the vectors, the magnitude of the sum and theta.
First find the trig form, then convert to rectangular form
at 70 pounds
<60.02, -35> I don't know how to get this number.
at 40 pounds
<28.28, 28.28>
at 60 pounds
<-2.43, 42,43>
now add the components to find the resultant of the system and use it to find the magnitude and direction angle.
for this problem, I have no clue what my teacher tries to say.
3) an airplane's velocity with respect to the air is 580 miles per hour, and it is heading N 60 degrees W. The wind, at the altitude of the lane, is from the southwest and has a velocity of 60 miles per hour. Draw a figure that gives a visual representation of the problem. What is the true direction of the plane, and what is its speed with respect to the ground?.
u= air speed= 580 = ?
v= wind speed = 60 = ?
w = u + v = < -459.9, 332.4> I don't know how to get this number?
I will have a test on Friday about this kind of problems, but I still don't get it. Can anyone please explain it to me step by step? Thank you for your help!
1) remember that vectors are little arrows with a certain magnitude and direction. v= i + j is a little arrow from the origin to point (1,1), while w= 2 i - 2 j is a little arrow from the origin to point (2, -2). So the formula for distance in 2d is sqrt( (x1-x0)^2 + (y1-y0)^2 ), using these two facts you can find the length of the two little "arrow" (or, alternatively, lines). This problem is really easy if you know how to take a dot product, but if you don't, don't worry as it can be done without it.
2) Use a similar technique to "decompose" vectors into their components. In general if a vector is a i + b j, then it's x component is a, and it's y component is b. However we are given an angle and a magnitude, so we need to decompose it into x and y components. To do this we visualize the vector as a little arrow with that direction given by the angle. We can can then visualize it as the hypotenuse of a right triangle, where x is the length of the horizontal leg and y the vertical leg (use trig functions, cosine and sine respectfully). So do this for those 3 vectors, and then add the components to get the resultant.
3) Use a similar procedure as 2, breaking each into component form and finding the resultant.
length of v and w = magnitude.
a + jb => Find the magnitude = |a+jb| = Sqrt of (a^z2 + b^2).
Hope it helps. Good Luck.
I am sure NJunJie meant
"ai+ bj => Find the magnitude = |ai+ bj|= Sqrt of (a^2+ b^2).
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
