Questions dealing with the Second Law of Motion
The discussion revolves around two physics problems related to the Second Law of Motion. The first problem involves calculating the weight of 600g of salami, where the correct answer is determined to be 5.9 N using the formula F=mg, with m being 0.6 kg and g as 9.8 m/s². The second problem addresses the reading of a scale when a 60-kg person is in an elevator moving at a constant speed of 3.0 m/s. The consensus is that the scale reads 588 N, as there is no change in velocity, indicating no acceleration.
  • Understanding of Newton's Second Law of Motion
  • Familiarity with the concept of weight as a force (F=mg)
  • Basic knowledge of free body diagrams
  • Ability to differentiate between mass and weight
  • Study the implications of constant velocity on forces in physics
  • Learn how to draw and interpret free body diagrams
  • Explore the relationship between mass, weight, and gravitational acceleration
  • Investigate real-world applications of the Second Law of Motion
Students studying physics, educators teaching mechanics, and anyone interested in understanding the principles of motion and forces.
miss_taken19
I have a couple homework problems that are causing me some trouble...
1. The weight of 600g of salami is:
a) 0.061 N
b) 5.9 N
c) 61 N
d) 5.9 kN
I found the answer to be a) 0.061N because F=mg so m=F/g which is
0.6kg/9.8m/sec.squared. The answer is actually b) 5.9 N but I can not figure out how the got this answer. Any insights to this?
Also...
2. A 60-kg person stands on a scale in an elevator. How many Newtons does the scale read when a) it is ascending at the constant speed of 3.0 m/sec.squared? b) it is desending at the constant speed of 3.0 m/sec. squared?
I am not sure how to find this out. On one hand, I think that I need to find the acceleration at these speeds. Yet I do not think that there is any acceleration when the speed is constant. Am I sort of on the right track here?
Thanks for your help!
for 1 isn't w = mg which give you .6kg *9.8 = 5.88 founded up to 5.9
for 2 what i think is this not sure if you have the answers to checkif it is correct f = ma f= 60 * 9.8 + and - 3 m/s just a guess not sure
Hi there Mistaken and welcome to PF.
Well, you have definatly come to the right place.
a) 0.061 N
b) 5.9 N
c) 61 N
d) 5.9 kN
I think you are getting a lttle confused here. Is 600g a force or a mass? Is weight a mass or a force?
Again, I think you getting a little confused here, you are not given any speeds; you are given accelerations, note the untis m.s-2. The scale in the lift actually measures the reaction force exerted by the lift on the perons. I think it would be helpful here if you drew a free body diagram. A good thread which previously described the mechanics is located https://www.physicsforums.com/showthread.php?t=120110".
Think about summing the forces acting; \sum F = m\vec{a}.
~H
Thanks for the help with the first one. It make a lot more sense now. I actually wrote the wrong units down for the second problem. The elevator is ascending and desending at 3.0 m/s not 3.0 m/sec. squared. So is there any force occurring here? I don't think so because there's no change in the velocities which means there is no acceleration. Am I right?
Spot on, so does the person's weight change?
~H
No, I don't think so.Their weight in Newtons would still be 588N (60kg * 9.8m/s. squared) since no other force is acting on their bodies except for the force due to gravity.
Spot on :smile:
Yes! Thanks for you help :)
My pleasure.
  • · Replies 42 ·
