Questions regarding DC circuits
  • Topic: Engineering
  • Thread starter R A V E N
    Circuits Dc
R A V E N
I have one confusing issue to resolve:
What is the resistance between points [tex]A[/tex] and [tex]B[/tex] in simple system illustrated in attachment?Wouldn`t be logical to assume that it is [tex]0[/tex],as current strives to flow through path with lowest possible resistance,if I understood it correctly?
Yes,I know that real transmission lines have some resistance,but in network anaylsis their resistance is considered to be equal to zero.
  • Circuit schematic: terminals A and B joined by a horizontal wire above a resistor labelled R, with the resistor in series on the bottom branch between two vertical wires.
You have a short circuit so what ever the resistance of the wire connecting point A and B.
CS
Yeah, it's zero assuming everything's ideal. Mathematically even, you have a wire ([tex]R=0[/tex]) in parallel with a resistor ([tex]R=R_0[/tex]). Then the parallel combination is:
[tex]R_{eq} = \frac{1}{ \frac{1}{0} + \frac{1}{R_0} } = \frac{1}{\infty + \frac{1}{R_0}} = 0[/tex]
I should probably have put some limits in there to be mathematically correct, but you get the idea.
