Quick Chebychev Inequality Question
  • Context: Graduate
  • Thread starter Thread starter Gooolati
    Inequality
14 replies · 3K views
Gooolati
Hello all,
I am currently working through a proof in my Real Analysis book, by Royden/Fitzpatrick and I'm confused on a part.
if f is a measurable function on E, f is integrable over E, and A is a measurable subset of E with measure less than δ, then ∫|f| < ε
A
Proof: for c>0
∫f = ∫f + ∫f <= (c)(m(A)) + 1/c ∫f
A {x in A s.t. f(x)< c} {x in A s.t. f(x)>=c} E
I understand why the first integral is less than (c)(m(A)) but I don't understand the second part.
Chebychev's inequality says that
if f is a non-negative measurable function on E then for any λ > 0
m{x in E s.t. f(x) >= λ} <= (1/λ)∫f
E
so here we would have that
m{x in A s.t. f(x)>=c} <= (1/c)∫f
A
and I don't understand how the book went from this step to getting that
∫f <= 1/c ∫f
any help is appreciated...thanks!EDIT: for some reason the integrals aren't lining up with the sets they are being integrated over, hopefully it is still readable, if not please ask
If you could tex it it would be a lot easier to read
What happened was I split the domain of A into two parts, one where f(x) < c and one where f(x) >= c
Then I applied Chebychev's inequality to the part where f(x) >= c but I was confused as to why
\int\limits_{x in A s.t. f(x)>=c} \ <= (1/c) * \int\limits_E \
edit: don't think that worked...but the second integral is integrating over E and the first one is integrating over {x in A s.t. f(x)>=c}
Is this what you're trying for (feel free to quote this post to see how tex works)
[tex]\int_{x\in A, f(x)\geq c} f \leq \frac{1}{c} \int_{E} f[/tex]
It's going to depend on the definition of A if it's actually true... I notice you mention a [itex]\delta[/itex] and an [itex]\epsilon[/itex] is there supposed to be some relationship between these numbers?
Thanks for this !
Yes the m(A) < δ and it is saying that if you integrate over this set A (a measurable subset of E), that the value of the integral will be < ε
If there is no relationship between delta and epsilon, then you are attempting to prove that your integral has a value of zero...
it is on page 92 of Real Analysis by Royden/Fitzpatrick, Fourth Edition. It is in Section 4.6 and it is Proposition 23.
The proposition says that for every epsilon greater than zero, there is a delta greater than zero
sorry I should have included that
So does anyone have any tips for me? I would appreciate it very much
I'm looking at a copy of the book and I don't see any integration being done where they split the set A up into two components in the proof of proposition 23
Really? They are trying to bound the integral of f over A. What do they do after they split up A?
I'm confused by your posts because they never split A up, which makes it hard to answer the question. They have two different functions they're integrating over (which seems to be missing from your posts and is probably related to the confusion), but they never split up A
So this is strange...
I looked up a copy of the book online, and the proof was entirely different than the copy I have. Something else to note, sometimes in my book when referring to previous propositions or theorems, rather than saying something like "By Theorem 25" it says "By Theorem (??)"
Could my book maybe be like an incomplete version? Maybe a copy that didn't make it to the final revision
Yes, I think you have some kind of draft version of the book. The proof in my copy of Royden is also completely different than what you say in this thread.
