Quick question on matrix calculus
  • Context: Graduate
  • Thread starter Thread starter majon
    Calculus Matrix
3 replies · 2K views
majon
I have a quick question. Say we have the following matrices, [tex]A = \begin{pmatrix} a \\ b \end{pmatrix}[/tex]
[tex]A^\dagger = \begin{pmatrix} a & b \end{pmatrix}[/tex]
[tex]B = \begin{pmatrix} \alpha & \beta \\ \gamma & \delta \end{pmatrix}[/tex] where the entries can be complex.
Now is the following expression correct?
[tex]\frac{\partial}{\partial A} (A^\dagger B A) = B A + B^\dagger A ?[/tex]
[itex]\partial/\partial A[/itex] doesn't make sense if A's entries are complex numbers. If they are complex variables, it would make sense, though.
Did you really mean to use [itex]A^\dagger[/itex] for the transpose of A, rather than the conjugate transpose of A?
Thanks for your reply Hurkyl. The entries are complex variables, I'll edit my question. And I meant to use the dagger (conjugate transpose) because this form of terms has a specific meaning where I'm using it.
The reason I asked about the dagger is because in your post, you wrote an equation stating [itex]A^\dagger[/itex] is the transpose of A. I wanted to clarify if that's what you meant or if that was just a typo.With complex variables, we normally define the derivatives so that
[tex]\frac{\partial z}{\partial z} = 1<br /> \qquad \qquad<br /> \frac{\partial z}{\partial \bar{z}} = 0<br /> \qquad \qquad<br /> \frac{\partial \bar{z}}{\partial z} = 0<br /> \qquad \qquad<br /> \frac{\partial \bar{z}}{\partial \bar{z}} = 1[/tex]
Following this, I imagine you want to have
[tex]\frac{\partial}{\partial A} A^\dagger = 0[/tex]I find these things much easier to deal with as differential forms:
[tex]d(A^\dagger B A) = (d A^\dagger) B A + A^\dagger (dB) A + A^\dagger B (dA)[/tex]
and so we would have
[tex]\frac{\partial}{\partial A} (A^\dagger B A) = 0 + 0 + A^\dagger B[/tex]
As a sanity check, this answer is a row vector. Which is what we want, since the derivative of a scalar with respect to a column is a row, IIRC.
If we had real variables, then
[tex]d(A^T B A) = (d A^T) B A + A^T (dB) A + A^T B (dA) = A^T B^T (dA) + A^T (dB) A + A^T B (dA) = A^T (dB) A + A^T (B + B^T) dA[/tex]
and so
[tex]\frac{\partial}{\partial A} (A^T B A) = A^T B + A^T B^T[/tex]
