Quick Subspace Question: Understanding A = [x+1,0] as a Potential Subspace
  • Thread starter Thread starter I Like Pi
    Subspace
The discussion centers on determining whether the set A = [x+1, 0] qualifies as a subspace of R². Participants clarify that for A to be a subspace, it must be closed under addition and scalar multiplication. The conclusion is that A does not satisfy the subspace criteria because the sum of two elements in A results in a vector of the form [x+2, 0], which does not conform to the required form [x+1, 0]. Thus, A is not a subspace of R².
  • Understanding of vector spaces and subspaces
  • Familiarity with R² notation
  • Knowledge of vector addition and scalar multiplication
  • Basic algebraic manipulation of expressions
  • Study the properties of vector spaces and subspaces in linear algebra
  • Learn about the criteria for a set to be a subspace
  • Explore examples of subspaces in R² and R³
  • Investigate the implications of linear transformations on subspaces
Students of linear algebra, educators teaching vector space concepts, and anyone interested in the foundational principles of subspaces in mathematics.
I Like Pi
Hey, I'm trying to figure out whether A = [x+1,0] is a subspace... I know it's probably simple but what I'm confused is that...
u+v must be an element of A. let u = [x1+1,0] and v=[x2+1,0]. Adding them together gives you [x1+x2+2,0], where (x1+x2) = x. Therefore it wouldn't be a subspace because you now have the form [x+2,0] which is not the same?
But if I look at it, [x1+x2+2,0] should be a subspace because you can get the same value with [x+1, 0] (let x1, x2 = -1 and let x = -1, both get 0 vector, for example)
Thanks for any help!
I think your second answer is closer. You want to show [x+1,0] is a subspace of R^2 if I understand what you are asking. What things do you have show to prove A is a subspace? And yes, [x1+x2+2,0]=[(x1-1+x2)+1,0]. So it is closed under addition if I've understood you correctly.
Well I know the three conditions. However, what I'm not getting is that you should have your u+v in the form [x+1,0], where x is made up of x1 + x2, or am I getting the definition wrong? In this case i have (x1 + x2 + 1)...
[x1+x2+2,0]=[(x1+1+x2)+1,0] is in the form [x+1,0] where x=x1+1+x2 as you said, isn't it? Sorry, I had a typo in the previous post.
Dick said:
[x1+x2+2,0]=[(x1+1+x2)+1,0] is in the form [x+1,0] where x=x1+1+x2, isn't it? Sorry, I had a typo in the previous post.
Oh yeah! So you can rearrange it anyway so that you get the correct form? I thought that the initial variable had to be represented by only variables (if that makes sense)...
Yeah, you are probably thinking too hard. The set of vectors [x+1,0] is really the same thing as the set of vectors [x',0]. Where x'=x+1. Where both x and x' can be any real number.
  • · Replies 54 ·
11K
