2025 Award
- 17,288
- 10,748
If there is backflow through the check valve, then it is minuscule, and irrelevant. When you are filling a bucket from a tap or faucet, and you cut off the water, does backflow occur?Ken Fabian said:Baluncore - I disagree - the amount may be small but there will be some backflow, a physical volume of water returning to the drive pipe before the delivery valve closes.
Are you insisting that physical backflow, rather than an acoustic depression wave, must take place for the ram pump to repeatedly cycle?
You seem to be saying that the pressure in the pump chamber could pulse and cycle, and that pulse pressure might be insufficient to open the check valve, due to the presence of air in the chamber.Ken Fabian said:However, in the traditional design above any air bubbles before the delivery valve would compress and rebound, making backflow (including some out the air valve), even if the delivery valve did not move - making it possible to cycle regardless. In the case of delivery valve not opening I would expect air to accumulate below it and reinforce that effect.
The peak pressure in the chamber is the ram pressure, independent of an air bubble below the check valve.
The pressure head across the air vent or restricted pinhole, is pushing some water or excess air, to flow out of the pump chamber. The relative flow rates are dictated by viscosity and inertia.
Not only does air moving through the check valve keep the air reservoir full, but the excess air, expanding as it rises, reduces the average density of the column, and so can push water to a greater height, a bit like a trompe in reverse.
