Random variable and probability
5 replies · 2K views · last reply
Imagin_e
Hi!
I'm searching for guidance and help since I don't know how to solve this problem. Here it is:
a) The two-dimensional random variable (ξ,η) is uniformly distributed over the square
K={(x,y): 0≤x≤1 , 0≤y≤1} . Let ζ=√ξ2+η2 me the distance between the origo and the point (ξ,η) . Calculate the probability P(ζ<1)
b) The three-dimensional random variable ξ=(ξ1,ξ2,ξ3) is uniformly distributed on a sphere, which has origo as it's center and a radius of 1. Calculate the probability that ξ ends in the area A which is given by:
A={(x1,x2,x3): 1/3 <√x12+x22+x32≤2/3} . You should, in other words, calculate :
P(1/3<ζ≤2/3) , where ζ=√ξ12+ξ22+ξ32
Note: √ means square root of.. I literarily have no idea where to start.
Hi Imagin_e:
A key point about these problems is "uniformly distributed".
For (a) this means the probability P is the area of a part of the unit square ζ<1. This square has total area = 1.
For (b) this means P will be a volume of a part of a sphere (1/3<ζ≤2/3) divided by the volume of the whole sphere.
Hope this helps.
Regards,
Buzz
(a) Since the probability distribution is uniform in the square K(take it as ABCD here), there P(ξ,η) = 1 for all points inside the square(why? : because ∫∫P(ξ,η)dξdη with 0<ξ<1 & 0<η<1 should be 1 and marginal distribution for ξ and η are uniform)
Now we need to find probability of all those points lying below the arc ADB(to the opposite of e, poly1 side), since the distribution is uniform,
therefore, we will have P(ζ<1) = Area below Arc / Area of square = π/4 (area of square is 1)
Geometry diagram of the unit square ABCD with corners A(0,0), B(1,0), C(1,1) and D(0,1), shaded, with a quarter-circle arc e running from D to B bulging toward C; the region between the arc and the square's corner at A is labelled poly1.
(b)Now I hope that you can do this as its similar to (a), but if you face problem, feel free to reply
Aakash Gupta said:
P(ζ<1) = Area below Arc / Area of square = π/2
Hi Aakash:
Your answer is flawed. What is the total area of the circle of which a part is inside the square? What is the fraction of the whole circle that is inside the square?
Regards,
Buzz
Buzz Bloom said:
Hi Aakash:
Regards,
Buzz
Oh sorry that must be pi/4, is there anything wrong apart from that?
Hi Aakash:
That's OK now.
Regards,
Buzz
