Range calculation for Airbus A320 aircraft
The discussion centers on the range calculation for the Airbus A320 using the Breguet Range Equation, specifically with the CFM-56-5A1 engine's specific fuel consumption (SFC). The equation is defined as R = (cl/cd) * (V/(g*SFC)) * ln(w0/w1), where the user calculated a range of 338 kilometers based on provided parameters. The primary issue identified was the incorrect unit conversion for SFC from lb/(lbf*hr) to kg/(N*s), which led to confusion in the calculation. The correct approach involves understanding the distinction between mass and force units, specifically lb and lbf, and applying the appropriate conversion factors.
  • Understanding of the Breguet Range Equation
  • Knowledge of unit conversions between imperial and metric systems
  • Familiarity with specific fuel consumption (SFC) calculations
  • Basic principles of aerodynamics related to lift-to-drag ratio (L/D)
  • Research the Breguet Range Equation in detail, including its applications in aviation
  • Learn about unit conversions specifically for fuel consumption metrics
  • Explore the aerodynamic principles affecting the lift-to-drag ratio (L/D) in aircraft
  • Investigate the performance characteristics of the CFM-56-5A1 engine
Aerospace engineers, aviation students, and anyone involved in aircraft performance analysis will benefit from this discussion, particularly those focused on range calculations and fuel efficiency in commercial aviation.
lowwwien
Hi to all,
the Task I struggle with, is the range calculation from an Airbus A320 with the Breguet Range Equation which is defined as:
with
  • V = velocity
  • g = gravity
  • SFC = specific fuel consumption
  • w0 = start weight
  • w1 = end weight
For my following calculation I assumed the flight condition in cruise at 36000 ft, V = 230 m/s, Fuel of 10000 kg, w0 = 68000 kg, w1 = 58000 kg and L/D = 15
The SFC for the engine (CFM-56-5A1) of an Airbus A320-200 has an SFC of 0,596 lb/(lbf*hr) which is converted into kg/(N*s) with the divsion of 3600 to an SFC = 0,000165555555 kg/(N*s)
This would lead to the following numbers in the breguet equation:
R = (15) * (230 / (9,80665*0,000165555555)) * 0,15906 = 338031,844 meters = 338 Kilometers
Did I bring in a mistake anywhere in my calculation? I think with one decimal more the result would be very realistic with 3380 km range for 10000kg fuel.
I'm very uncertain with the unit change for the SFC. Could this be the Problem?
Thank you very much in advance.
lowwwien said:
The SFC for the engine (CFM-56-5A1) of an Airbus A320-200 has an SFC of 0,596 lb/(lbf*hr) which is converted into kg/(N*s) with the divsion of 3600 to an SFC = 0,https://www.physicsforums.com/tel:000165555555 kg/(N*s
This is not correct. 1 lbf is the gravitational force exerted on a mass of 1 lb. In other words, g * 1 lb/lbf = 1.
In other words: Yes.
Likes berkeman
Orodruin said:
This is not correct. 1 lbf is the gravitational force exerted on a mass of 1 lb. In other words, g * 1 lb/lbf = 1.In other words: Yes.
So the multiplication g*SFC is incorrect? And the equation should look like R = (cl/cd) * (V/(SFC)) * ln(w0/w1) ?
No. The unit conversion is wrong. However, if you multiply the g into SFC, you get the numerical value you obtained for SFC (but with units 1/s).
Also, whenever you are unsure about a unit conversion, I find the best thing to do is to double check with Wolfram Alpha or Google.
Ok, Thanks!
I guess I found the right conversion:
TSFC = (0.596lb)/(lbf⋅h) = ((0.596lb)/(lbf⋅h))⋅(4.448N/lbf)⋅((0.4536kg/lbm)^(−1))⋅((3600s/h)^(−1)) * (9,81m/s^2) = 0,0001655555555 1/s
Can you confirm that this would be the right result of the conversion?
Now your ingoing and outgoing quantities do not even have the same dimension ... lb and lbf are units of mass and force, respectively.
But the weight of 1 lb is 1 lbf right? So the ingoing is in fact 1/h and then converted into 1/s.
Test: I get the same result, if I divide 0,596 / 3600
Yes. In standard gravity. 1 lbf = 1 lb * g.
No. Again, lbf and lb are units of different physical dimension.
"As a guy who has been working with these unit all my life, I can tell you that 1 lbm/hr is the same as 0.4536 kg/hr. The weight of this is (0.4546)(9.8)=4.448 N/hr. And we know that 1 lbf=4.448 N. So, to convert from imperial to metric in this case, all you need to do is divide by 3600" quote from Mr. Chestmiller Post #24 of Homework Help: Unit conversion:lbm/lbf*h to (N/s)/N
Right, lbf and lb are different Units. But now I'm confused if I can use the method from Mr. Chestmiller to receive the correct result.
Please include links if you are going to quote other threads.
Did you read the rest of that thread? And no, you cannot just divide by 3600 to go from hours to seconds. You need to take care of the conversion from lb/lbf to kg/N. This is a dimensionful quantity.
Edit: Also note that the title of that thread makes no sense either. You cannot convert lb/(lbf h) to (N/s)/N. Different physical dimensions.
I did read all posts.
First to convert lb/lbf to kg/N I would muliply my starting value 0,596 by 0,4535 (lb to kg) and divide it by 4,448 (lbf to N).
What I need is end unit of kg/N*s so I would divide everything with 3600.
I need a value of meters at the end of the range equation so now:
-I mulitply the result from above by the g-force and receive a end unit of 1/s
-velocity/(1/s) = m
This is not equivalent to just dividing everything by 3600.
Do you know how the conversion should be done? I honestly don't know how I should proceed to get the proper value and unit out of the conversion.
Yes.
You described a valid procedure in #14. It is not equivalent to just dividing by 3600. But the better way of doing things is to keep g algebraic. 1 lbf = g * 1 lb so 1 lb/lbf = 1/g. What happens if you use this fact in your expression for SFC?
Edit: i.e., 0.596 (lb/lbf)/hr = ...
