Raoult's Law Problem: Estimate Mole Fractions at 65K
  • Thread starter Thread starter Samuel1321
    Law
The discussion focuses on estimating mole fractions of nitrogen (N2), oxygen (O2), and argon (Ar) in both liquid and gas phases when 1 mole of air at 300 K and 4 atm is cooled to 65 K. Participants emphasize the application of Raoult's Law and the Antoine equation for vapor-liquid equilibrium (VLE) calculations. The initial total pressure is confirmed as 4 atm, and the need for boiling points and enthalpies of vaporization is highlighted. Participants suggest using the Clausius-Clapeyron equation to find the final pressure after cooling, while also discussing the setup of equations to determine the split of liquid and vapor phases.
  • Understanding of Raoult's Law and its application in vapor-liquid equilibrium.
  • Familiarity with the Antoine equation for calculating vapor pressures.
  • Knowledge of Clausius-Clapeyron equation for phase change calculations.
  • Basic thermodynamics concepts, including enthalpy of vaporization.
  • Research the Antoine equation parameters for nitrogen, oxygen, and argon.
  • Learn how to apply the Clausius-Clapeyron equation to calculate changes in pressure with temperature.
  • Study vapor-liquid equilibrium (VLE) calculations for multi-component systems.
  • Explore methods for determining mole fractions in liquid and vapor phases after phase changes.
Chemical engineers, thermodynamics students, and anyone involved in phase equilibrium calculations in gas-liquid systems will benefit from this discussion.
Samuel1321
Consider air to be made up of only N2 (78 mole %), O2 (21%) and Ar (1%)
Estimate the mole fractions of each in both the liquid and gas phases if 1 mole of air at 300 K and 4 atm. total pressure were cooled to 65 K in the same volume
Raoult's law Pi = Pi* xi
So I know that the atmospheric pressure is 760 torr. So before they are cooled
vapor pressure of N2 would be (0.78)(760) torr
Vapor Pressure of O2 would be (0.21)(760) torr
Vapor Pressure of Ar would be (0.01)(760) Torr
I'm not sure how should I proceed. Maybe I should use the Clausius Clapeyron equation to find the final pressure after cooling it down? But what delta H value should I use?
Look at the question again; what is the initial total pressure?
You need to know the boiling points and enthalpies of vaporisation of the gases, but these should be easy to look up.
What are the Antoine equations for these three substances?
The initial total pressure is 4 atm.
Should I just find the final total pressure first using the clasius clapeyron equation? The problem is if I use the CC equation, which enthalpy of vaporization should I use?
I have not learned that equation yet, is there another way to solve this problem?
The Antoine equation is an 3-parameter very accurate fit to the integrated Clausius-Clapeyron equation. The parameters are available for common substances like oxygen, nitrogen, and argon, so you don't have to integrate the CC equation to describe the VLE behavior of the pure species. Google it, and get the Antoine equation parameters for your 3 species. This way, you don't need to know the boiling point, and the heat capacities of the vapor and liquid as functions of temperature, and you don't need to integrate the CC equation.
Of course, to solve your problem, the VLE behavior of the pure species is only the first step. Given the overall mole fractions of the 3 species, you need to determine the split of liquid and vapor, and the mole fractions of the 3 species in the liquid and in the vapor.
@Samuel1321 Do you have any idea how to go about setting up the equations for this problem? It is pretty challenging. There will be two main unknowns: the fractional split of liquid and vapor and the final pressure. I can lead you through how to set up the two key equations, if you are willing to work with me. Any interest?
14K
17K
10K
12K
