Rate of change of the magnetic field
The problem involves a square loop of wire with a given resistance and dimensions, where a changing magnetic field induces a current. Participants are exploring how to determine the rate of change of the magnetic field strength in Tesla per second.
  • Participants discuss the relationship between induced current and magnetic flux, with attempts to apply relevant equations such as Ohm's Law and the formula for EMF. There are questions about the necessary information to solve the problem, particularly regarding the magnetic field strength.
Some participants have provided guidance on the equations that relate EMF to magnetic flux, while others express uncertainty about the information needed to proceed. The discussion reflects a mix of interpretations and attempts to clarify the problem setup.
Participants note a lack of specific information regarding the magnetic field strength, which is crucial for solving the problem. There is also mention of formatting issues related to mathematical notation.
talaroue
The resistance of the loop is 0.55 Ω. At what rate the magnetic field strength increasing or decreasing? (a=8.4 cm, I=148 mA. Give answer in T/s.)
The loop is a square, so all the distances around are a=8.4 cm
dI=AdB
dI=rate of change of the flux
A=area
B=magnetic field
I found V by using Ohm's Law V=IR, which is the same as emf
but now I am lost, I feel like I need to find B, obvious reasons. Do I just use the equation
B=Uo*N*I/2R
N=1 because only 1 loop
Uo= constant
I=current
R=radius, so half of a?
I am still lost, no matter how I go about solving this I seem to be missing 1 or 2 bits of information... usually B is one of those.
Okay, let me restate this:
A square loop of wire has sides that are 8.4 cm long. The wire in the loop has a total resistance of 0.55 Ω. There is a magnetic field perpendicular to the plane of the loop which is spatially uniform, but is changing in time. If the changing magnetic field induces a current of 148 mA in the wire loop, at what rate, in T/s, the magnetic field strength through the loop increasing or decreasing?
Does that accurately describe what the problem is asking?
If so, you do have enough information. Figuring out the EMF was a good first step, but now you need an equation that relates that EMF to magnetic flux. Do you know what it is?
(your B=Uo*N*I/2R is not the right equation for this problem)
EMF=N(dI/dt)
dI is delta flux?
Yep, that's it. But note that nobody really uses I for flux. Normally the formula would be written
[tex]\varepsilon = N \frac{\mathrm{d}\Phi}{\mathrm{d}t}[/tex]
right, I just didnt know how to right Phi on the computer
Some people have signatures with the Greek letters that you can copy and paste from. There are other ways too, depending on what operating system you're using.
