Ratio of net gravitational pull on moon
The discussion focuses on calculating the ratio of the net gravitational pull on the moon during its new and full phases. The gravitational forces exerted by the Earth and the Sun are considered, with the correct approach being to measure distances from the centers of the celestial bodies. The user successfully resolved the issue by calculating the net forces in both positions and determining their ratio. This method confirms the importance of accurate distance measurements in gravitational calculations.
  • Understanding of Newton's Law of Universal Gravitation
  • Familiarity with gravitational force calculations
  • Knowledge of celestial mechanics
  • Ability to perform ratio calculations
  • Study Newton's Law of Universal Gravitation in detail
  • Learn how to calculate gravitational forces between multiple bodies
  • Explore celestial mechanics and orbital dynamics
  • Investigate the effects of distance on gravitational force
Astronomy students, physics enthusiasts, and anyone interested in gravitational interactions between celestial bodies.
Metalsonic75
[SOLVED] Ratio of net gravitational pull on moon
A new moon is almost exactly in line between the Earth and the sun. A full moon is on the opposite side of the Earth from the sun. What is the ratio of the net gravitational force on the moon when it is new to when it is full?
I tried calculating the gravitational pull on the moon by the Earth and sun when the moon is in each of the two positions. I used the masses of the three bodies, the radii, and the distances between them, but I was halted in my calculations because I couldn't figure out if the distance given in the textbook between the sun and the Earth was measured from the center of the bodies or not. And anyway, I feel like I'm taking the wrong way around, and that the answer should be something simple. I would really appreciate some help.
The value of the distance from the sun to the Earth should be as measured from their centres. Your approach is correct. You need to calculate the gravitational force from the Earth and the Sun in each position then work out the net force. Once you have the net force you can find the ratio of the net forces.
Thanks! I was able to solve the problem!
  • · Replies 40 ·
  • · Replies 18 ·
