Rational function that approximates e^x
  • Context: Undergrad
  • Thread starter Thread starter Ledsnyder
    E^x Function Rational
6 replies · 3K views
Ledsnyder
Is there a rational function,not series, that approximates e^x
for example (x+1)/(x+3)
What do you mean by "approximates"? A given function, rational or not, has a specific difference from [itex]e^x[/itex]. We can always find a function, for example by truncating the Taylor's series to a polynomial, that "approximates" [itex]e^x[/itex] to a desired degree of accuracy. The difference is that the series, [itex]\sum_{n=0}^\infty[/itex] does NOT 'approximate' [itex]e^x[/itex], it is exactly equal to it.
That is not at all the question you asked before. However, the standard Taylor's series for the exponential, [tex]\sum_{n=0}^\infty \frac{x^n}{n!}[/tex]
is a very "rapid" approximation to the exponential.
Truncating the series after a fixed number of terms is not a good method of evaluating [itex]e^x[/itex] numerically for large [itex]|x|[/itex], since one loses precision from calculating the large values of [itex]x^n[/itex] and [itex]n![/itex] and the remainder may be large.
To the OP: Woolfram gives a couple of continued fraction expressions for [itex]e^x[/itex]; truncating these will give you a rational function approximation. But it is better to use a library function for exp if at all possible.
It depends what type of approximation you want. One common one is an approximation such that the function and its derivatives match the approximation up to some degree
e^{-x}\sim P(x)/Q(x)\\
\text{where}\\
P(x)=\sum_{k=0}^m \frac{(m+n-k)!m!}{(m+n)!k!(m-k)!}x^k
Q(x)=\sum_{k=0}^n \frac{(m+n-k)!n!}{(m+n)!k!(n-k)!}x^k
matches up to the n+m+1 derivative
see
http://mathworld.wolfram.com/PadeApproximant.html
http://en.wikipedia.org/wiki/Padé_table#An_example_.E2.80.93_the_exponential_function
http://wwwhome.math.utwente.nl/~vajtam/publications/temp00-pade.pdf
