Why Is Magnification Undefined for a Point Object in Ray Diagrams?
The magnification for a point object is fundamentally undefined due to the lack of size associated with a single point. In ray diagrams, magnification can still be discussed by considering the angles between rays from multiple points, which allows for a ratio-based definition. For instance, in an afocal telescope, the magnification is evident through the change in angle and apparent spacing of objects at infinity. Thus, while a point object has no size, the concept of magnification can be applied through angular relationships in optical systems.
  • Understanding of basic optics principles, including ray diagrams.
  • Familiarity with the concept of magnification and its mathematical representation, M = h_i / h_o.
  • Knowledge of angular relationships in optics, particularly in relation to lenses and telescopes.
  • Experience with drawing and interpreting ray diagrams for optical systems.
  • Explore the concept of angular magnification in optical systems.
  • Learn about ray tracing techniques for complex optical systems.
  • Investigate the behavior of light rays in afocal telescopes and their applications.
  • Study the implications of point sources in various optical scenarios.
Students of optics, optical engineers, and anyone interested in understanding the principles of magnification in ray diagrams and optical systems.
Krushnaraj Pandya
I read that the magnification for a point object is undefined, but when we draw ray diagrams we consider the rays to be emanating from a point source and also define magnification for it- what am I missing?
(conceptual query)
The magnification has meaning only when the image of a second point that originates at the same distance, but at a different height (a point on-axis for the second point is ok) is found. Then, the magnification is defined as ## M=\frac{h_i}{h_o} ##.
“Magnification” can be used a couple of ways. They all can be related back to the idea of image to object ratio, but sometimes when designing an optical system it is useful to note other things that also relate to magnification.
Picture the usual single lens diagram with a magnified real image. You see the difference in the size of the object and image. However do you also notice the angle between the rays at the object and image? The ratio of the angles is also the magnification. That’s how you can show single points and still talk about magnification. If you had more than one field point the distance between them would be magnified.
Now consider an afocal telescope. The rays coming in and going out are parallel. We can see the magnification both in the decreased size of the pupil and the increased size of the angles. The more common meaning of magnification appears when you put your eye behind the telescope and the magnification translates to the apparent spacing of the objects. Note that here with the objects at infinity it becomes hard to use the object size/image size definition and the angles are the best way to define it
(conceptual query)
When we draw ray diagrams we consider rays from two points!
We usually draw the object as a small vertical arrow based on the axis.
We draw the "usual" rays from the head of the arrow and discovery where the image of the head of the arrow will be.
We then include the fact that the "usual" rays drawn from the base of the arrow just pass along the axis, and chose the perpendicular on the axis as the other end.
Try a ray diagram from BOTH ends of a "floating, oblique arrow" to see what you get.
Note: It is reasonable that magnification of a point object is undefined, since a single point has location, but no size. When you find the location of the image point, it will also have zero size, so we could claim any magnification we like: 2X , 3X , 12X because 2 x 0 = 0, 3 x 0 = 0, 12 x 0 = 0, so no hints as to what the answer is.
  • · Replies 16 ·
10K
