Rayleigh Quotient: Finding 2nd Eigenvalue & Vector
  • Thread starter Thread starter dirk_mec1
    quotient Rayleigh
7 replies · 5K views
dirk_mec1
Let A be a symmetric n x n - matrix with eigenvalues and orthonormal eigenvectors [tex](\lambda_k, \xi_k)[/tex] assume ordening: [tex]\lambda_1 \leq...\leq \lambda_n[/tex]
We define the rayleigh coefficient as:
[tex] R(x) = \frac{(Ax)^T x}{x^T x} [/tex]Show that the following constrained problem produces the second eigenvalue and its eigenvector:
[tex] min \left( R(X)| x \neq 0, x \bullet \xi_1 = 0 \right) [/tex]
In the first part of the exercise I was asked to proof that (without that inproduct being zero) the minimalisation produces the first eigenvalue. The idea was to use lagrange multipliers but I don't how to use it here.
Do I need to use Lagrange multipliers?
Not really. The dot product condition tells you that x is ranging over linear combinations c_i*xi_i with c_1=0. It's just the same as the first problem with the first eigenvector thrown out.
So if I understand correctly the eigenvectors are orthogonal to each other, right?
and so:
[tex]x= c_2 \cdot \xi_2+...+c_n \cdot \xi_n[/tex]
So I just substitute the above expanded x?
Dick said:
Yes, and minimize over c2,...,cn.
I get this:
[tex] \frac{\sum_{2=1}^n c_i^2\lambda_i}{\sum_{i=2}^n c_i^2} [/tex]
but how do I prove that [tex]\lambda_2[/tex] is the minimum? I've tried putting the partial deratives to zeros and failed.
"In the first part of the exercise I was asked to proof that (without that inproduct being zero) the minimalisation produces the first eigenvalue. The idea was to use lagrange multipliers but I don't how to use it here." I thought that meant that you proved the first part using lagrange multipliers. Did you skip that part? Because what you have now looks almost exactly like the first part. If you want to spell out a repetition of the proof of the first part, yes, use lagrange multipliers.
No I didn't skip it but I showed there that the minimizer should be an (orthogonal) eigenvector and upon substitution I get a [tex]min( \lambda_i)[/tex] from which the first eigenvalue results.
With the length of the vector c is one? So the problem is minimize:
[tex]\frac{ \lambda c^Tc}{c^Tc}[/tex] with [tex]\lambda[/tex] and c vectors.
