RC circuit where source depends on capacitor current
The discussion revolves around the analysis of an RC circuit where the voltage source is dependent on the current through the capacitor. Participants explore the application of Kirchhoff's voltage law (KVL), the behavior of the capacitor at different time intervals, and the implications of the controlled source in the circuit. The conversation includes attempts to derive equations for current and voltage over time and addresses uncertainties in the calculations.
  • One participant derives a KVL equation resulting in V = 10Io and substitutes variables to arrive at a differential equation dq/dt - 50000q = 0, but expresses uncertainty about the correctness of their approach and the value of C.
  • Several participants repeatedly ask to review the circuit diagram, indicating confusion about the setup and calculations.
  • A participant suggests that the controlled source behaves like a resistor, prompting a discussion about the significance of this observation.
  • Another participant points out a sign mistake in the KVL equation and questions the ambiguity of the initial current Io(0), suggesting that it should be 0 before t=0 due to the capacitor acting as an open circuit.
  • There is a consensus that the voltage across the capacitor remains continuous, leading to discussions about the implications for charge Q at t=0.
  • Participants express confusion about the relationship between charge, voltage, and current, with one suggesting that q should equal CV.
  • There is a back-and-forth regarding the correction of the KVL equation, with participants debating the correct formulation and signs.
Participants generally agree on the behavior of the capacitor and the continuity of voltage across it, but there are multiple competing views regarding the correctness of the derived equations and the implications of the controlled source. The discussion remains unresolved with respect to the calculations and the correct formulation of the KVL equation.
There are limitations in the clarity of the initial conditions, particularly regarding the definition of current Io(0) and the assumptions made about the circuit's behavior at t=0. The discussion also reflects uncertainties in the mathematical steps taken by participants.
miyelmunshi
Find Io(t) for t>0 of the circuit shown
I(t) = C x dv/dt
V = Q/C
I did a kvl loop and got V + 5Io - 15 Io = 0
So, V = 10Io
Then, substituted dq/dt for Io and q/c for V
I get to dq/dt - 50000q = 0
solving this equation i get q = C x e^50000q (c for constant)
my Io = dq/dt
so Io now is 50,000Ce^50000q
now my Q(0) is 3 x 10^-5
So my Io (0) should be, 50,000Ce^1.5
I don't know how to find the C now or any of the things i did is even correct
I know the answer should be
15e^-25000t for V(t)
0.75e^-25000t for Io(t)
See the diagram carefully?
Ummm can not figure out anything unfortunately :)
are rest of my process correct ?
Ok i looked at it again so i can i do a kvl loop for Io(0) and put the voltage of capacitor as 15 v ? then get the value of Io(0) ?
It might be useful to note that the control law for the controlled source is 5*Io and ask yourself what kind of electronic component has the property that the voltage across it is proportional to the current through it. In other words, what standard passive component is the controlled source equivalent to?
a resistor maybe ? but why is that important ?
You made a sign mistake in your the KVL equation in your original post.
You need to be a little more precise about ##i_0##. ##i_0(0)## is ambiguous because there's a discontinuity at ##t=0## in ##i_0##. Can you tell us what ##i_0(0^-)## is, assuming the switch has been in position 1 for a long time?
in position 1 as far as i know, no current flows through the circuit as there is no voltage difference, so shouldn't Io be 0 then ? for t < 0 ?
Right. The capacitor acts like an open circuit after it's charged, so ##i_0(0^-)=0## and ##V(0^-)=15~\rm V##.
Instead of focusing on ##i_0##, consider ##Q## for ##t>0##. Recall that the voltage across a capacitor is continuous, so you know that ##V(0^+) = V(0^-) = 15~\rm V##. What does this mean about ##Q(0^+)##?
i don't really understand what you are getting into but q should be CV so, 3x10^-5 maybe ?
miyelmunshi said:
i don't really understand what you are getting into.
Like what part?
Right, other than the lack of units. So you essentially have an expression for ##q(t)## for ##t>0##, right? From that, you can find the results you want (after you fix the sign mistake).
vela said:
Like what part?Right, other than the lack of units. So you essentially have an expression for ##q(t)## for ##t>0##, right? From that, you can find the results you want (after you fix the sign mistake).
um if i fix the sign mistake will the equation be V + 20 Io?
That's ,not an equation.
Perhaps you mean that ## V = 20 I_0 ## .
If the controlled source were replaced with a 5 ohm resistor, would the signs in your equation be any different?
i don't think so
I meant v+20Io = 0
  • · Replies 46 ·
11K
  • · Replies 21 ·
