The discussion revolves around the reaction moment experienced by an internal combustion engine when the RPM is increased. Participants explore how this reaction moment is transferred to the engine block and the vehicle, considering various mechanical interactions and forces at play.
- Exploratory
- Technical explanation
- Debate/contested
- Some participants note that increasing RPM causes the car to shake in the opposite direction of crankshaft rotation due to the reaction moment.
- There is a discussion about the role of oil in the engine, with some arguing that oil primarily reduces friction and does not transfer moments directly.
- Gas pressure in the cylinders is mentioned as a key factor that pushes the piston and cylinder head apart, with forces being transferred through engine mounts to the car body.
- One participant suggests that the crankshaft must push the block and the car in the opposite direction to accelerate angularly, drawing an analogy to construction workers experiencing wrist fractures when a drill bit hits a steel bar.
- Another point raised is that the reaction moment is transferred through contact between the piston thrust side and the cylinder wall, with some participants agreeing on this mechanism.
- There is speculation about how the engine would behave in space, with discussions on moment of inertia and angular momentum conservation.
- Some participants introduce the concept of rotary engines and engines where both the crankshaft and block rotate in opposite directions, questioning the implications of such designs.
- The side load on the piston during the power stroke is discussed, with some suggesting it could be a significant factor in torque transfer, while others argue it is a distraction relative to usable engine torque.
Participants express multiple competing views on how the reaction moment is transferred and the significance of various forces involved. The discussion remains unresolved with no clear consensus on the mechanisms at play.
Some participants highlight the complexity of the interactions between the crankshaft, piston, and engine block, noting that assumptions about the roles of oil, gas pressure, and mechanical connections may vary. There are also references to specific engine designs that complicate the discussion.
