Reading formatted input in fortran
2 replies · 12K views
agalya
format statement to read input in fortran
hello everyone,
I've to read this following line in fortran,
I don't know to read the exponential form
please help me
3.49E+03 2.73E+01 2.01E-01 9.16E-02 5.94E-02 5.11E-02 3.27E+04 3.27E+04
can somebody help me to write the format statement to read the whole line
or can please tell me how should I read the exponential data eg 3.49E+01 and 9.44E-09
thank you,
agalya
Taken from this site: http://elsa.berkeley.edu/sst/fmttop.html
The E format allows the user to enter data stored in scientific notation. The syntax of the E format is the same as the F format:
Ew.d
Here W is the total width of the variable, including exponent, while D indicates the number of implied decimal places in the mantissa. The data field should contain the mantissa and the letter E followed by an integer indicating the power of ten to which the mantissa is to be raised. For example, E6.0 would read `1234E2' as `123400' (1234.0 x 10^2), while E6.1 would read `1234E2' as `12340' (123.4 x 10^2). As before, any decimal actually coded overrides the format specification, so that both E6.0 and E6.1 would read `123.4E2' as `12340'. "
Try also this site, for more details: http://www.cs.mtu.edu/~shene/COURSES/cs201/NOTES/chap05/format.html
If the data is separated by spaces as you have here, you can use the default format (*):
Code:
      real a, b, c, d, e, f, g, h
      open (unit=10, file='agalya.txt')
      read (10, *) a, b, c, d, e, f, g, h
      write (*, *) a, b, c, d, e, f, g, h
      end
This "write" statement doesn't give you the numbers in the same format in which you read them; it uses its own default format. You can of course specify your own output format as needed.
