Reading pH: Is There A More Precise Way to Measure Volume?
  • Thread starter Thread starter yolo123
    Graph Ph Reading
5 replies · 2K views
yolo123
For b), do I really need to look at the graph to get the volume of HCl poured? Is there not a more precise way?
? You are given 3 place accuracy for the M of the HCl. You can't get better accuracy than the standards you are working with. If you can obtain the (digital) data, then the graph would be less preferable, but converting points on a graph to a table is unlikely to improve your accuracy (as compared to precision), especially when the data appears to be (suspiciously) well behaved, as in this case. (In other words, if there were more noise in the data, then converting to a table then doing least squares regression would likely help). I assume you understand the difference between precision and accuracy (as well as the difference between efficiency and effectiveness).
abitslow said:
If you can obtain
Bolding mine. OP doesn't say anything about being given these data. Looks like this is a question quoted verbatim from some exam.
